Author Topic: PixInsight 1.8.5 Ripley does not run in my computer windows 7 64-bits  (Read 3282 times)
Offline arvidas
I have installed the last available versiĆ³n of PixInsight 1.8.5 Ripley avalable in the downloads section. The installation was OK but when I double-clicked the PI icon the program does not start, my laptop seems to start to do something but then stops and Pixinsight does not start.
My laptop has an Intel Core I5-4200M 2.50 Ghz processor, 4 Gb of RAM and windows 7 professional servipack 1 64-bits.
I have desinstalled and reinstalled PixInsight but no solution was found.
Please, can you help me?
Fernando
Offline John_Gill
I have seen this happen.  Try this, right-click on the PI icon and then select "Open"
Look up
John
APM 107/700 apo on CGX mount
ZWO Optics - Autoguiding
ZWO1600mm and filters
Offline M Covington
Since no one has replied, I'll take a wild guess.  Do you have the current Java runtime engine?  You might try downloading it and installing it and see what happens.  I am thinking maybe you have a damaged Java runtime environment.  Just a wild guess though.
Java is not required by PI. No need to install it. Did you check the system requirements http://pixinsight.com/sysreq/index.html ? They state that Win7 has limited support only. Do you use an anti virus? Maybe temporarily deactivate it during installation.
Offline M Covington
Look up
John
That is very likely to be it.
Offline arvidas
Thank for all your responses. I have tried to desactivate antivirus temporally and resinatall PI. right-click and open but no one works. I have found and error file (C:\temp\WER5051.tmp.WERInternalMetadata.xml)  generated by windows to report errors. It said the following:
<?xml version="1.0" encoding="UTF-16"?>
-<WERReportMetadata>
-<OSVersionInformation>
<WindowsNTVersion>6.1</WindowsNTVersion>
<Build>7601 Service Pack 1</Build>
<Product>(0x30): Windows 7 Professional</Product>
<Edition>Professional</Edition>
<BuildString>7601.23915.amd64fre.win7sp1_ldr.170913-0600</BuildString>
<Revision>1130</Revision>
<Flavor>Multiprocessor Free</Flavor>
<Architecture>X64</Architecture>
<LCID>3082</LCID>
</OSVersionInformation>
-<ParentProcessInformation>
<ParentProcessId>5592</ParentProcessId>
<ParentProcessPath>C:\Windows\explorer.exe</ParentProcessPath>
<ParentProcessCmdLine>C:\Windows\Explorer.EXE</ParentProcessCmdLine>
</ParentProcessInformation>
-<ProblemSignatures>
<EventType>APPCRASH</EventType>
<Parameter0>PixInsight.exe</Parameter0>
<Parameter1>1.8.5.1353</Parameter1>
<Parameter2>598b2136</Parameter2>
<Parameter3>Qt5WebEngineCore.dll</Parameter3>
<Parameter4>5.9.0.0</Parameter4>
<Parameter5>592fed42</Parameter5>
<Parameter6>c0000005</Parameter6>
<Parameter7>000000000114cd65</Parameter7>
</ProblemSignatures>
-<DynamicSignatures>
<Parameter1>6.1.7601.2.1.0.256.48</Parameter1>
<Parameter2>3082</Parameter2>
<Parameter22>7d0d</Parameter22>
<Parameter23>7d0d6d06687d58ed16e74f4ab543e55c</Parameter23>
<Parameter24>265e</Parameter24>
<Parameter25>265e162b6a299ec1f4b6f1c3bb544d2f</Parameter25>
</DynamicSignatures>
-<SystemInformation>
<MID>0CA3BA48-6158-4550-8951-137468D41C3D</MID>
<SystemManufacturer>LENOVO</SystemManufacturer>
<SystemProductName>20AN0072SP</SystemProductName>
<BIOSVersion>GLET39WW (1.14 )</BIOSVersion>
</SystemInformation>
</WERReportMetadata>
Does someone have idea about it?
It seems that it refers to an APPCRASH eventype related to PixInsight.exe
Thanks in advance
Fernando
« Last Edit: 2018 January 07 04:49:51 by arvidas »
Hmm....
Maybe some problem with the graphics driver? Can you try to start PI with some special options:
C:\Program Files\PixInsight\bin>PixInsight --no-share-opengl-contexts
C:\Program Files\PixInsight\bin>PixInsight --opengl=raster
Just a wild guess.
Offline arvidas
Thank you Georg,
I have tried your recommendations without success. I do not know what to do... I will think about it.
Fernando
Offline M Covington
It has to do with the QuickTime5 graphics system used by PixInsight.
If I were you I would e-mail PixInsight for support, or use the "Bug reports" topic in the forum.
Qt is not QuickTime...
Offline M Covington
Sorry, my mistake.  It is the QT portable GUI system.
I see a lot of web sites offering to "fix" QT5WebEngineCore.dll but have no idea which ones are trustworthy.
This might help.
http://wiki.qt.io/About_Qt
