Author Topic: Subframe Selector process  (Read 1358 times)
Offline Alexis Jaldin
« on: 2018 January 01 16:52:19 »
Hello
Someone use SubframeSelector process?  Can  you teach me what parameters I have to use with Canon T5i Modified camera.
I found this tutorial,  but I'm still confuse
http://www.lightvortexastronomy.com/tutorial-pre-processing-calibrating-and-stacking-images-in-pixinsight.html
regards
Alexis
Offline John_Gill
Re: Subframe Selector process
« Reply #1 on: 2018 January 02 03:24:02 »
These are the settings I use with my Celestron 8"EdgeHD Scope
Add Debayered files
System Parameters
Pixel Scale form nova.astronomy.net
(Canon 600d - 1.42 and with 0.7 reducer - 1.92
ISO      Gain     RN       DC*
100     8.79   15.5     0.146
200        4.40   8.1     0.081
400        2.19   4.8     0.048
800        1.12   3.2     0.039
1600     0.58   2.5     0.036
3200     0.29   2.2     0.041
6400     0.15   2.1     0.039
12800   0.07   1.9     0.035
Gain = conversion factor, electrons per ADU
RN = readout noise, electrons r.m.s
DC* = electrons per pixel per second (bogus value, see below)
ISOs 6400 & 12800 are in fact digitally stretched ISO 3200
Camera Resolution - 16-bit
Scale unit - Arc seconds
Star detection
 - Star detection layers - 4
 - Noise reduction layers - 2
Measure
Most times I just use the defaults for the system parameters and I normally select the image with the highest SNR value.  If there are images with similar SNR values, then I select the image with the highest SNR and lowest Eccentricity value.  Some people use a fancy formula to work out the best value, but I don't bother too much with that :)
Look up
John
APM 107/700 apo on CGX mount
ZWO Optics - Autoguiding
ZWO1600mm and filters
« Reply #2 on: 2018 January 02 16:01:16 »
Thanks John for your reply!!!
I will check these parameters and try
 I will let you know
Thanks a lot
Alexis
Offline starwind
« Reply #3 on: 2019 September 19 16:32:21 »
I tested the sensor parameters for my T3i and these are what I get. The gains are diff from John's nos. I used Craig Stark's method described here: https://www.cloudynights.com/articles/cat/column/fishing-for-photons/signal-to-noise-part-3-measuring-your-camera-r1929 Also verified with PIs BasicCCDParameters Script
ISO    Gain e/ADU   Read Noise DN   Read Noise e-   Saturation e-   DR stops   Max ADU
100    2.07             6.8                    14.1                24828            10.8         14043
200    1.07             7.1                    7.6                14747            10.9         15831
400    0.54             8.6                    4.6                7483             10.7     15831
800    0.28             11.7                3.2                3812              10.2     15831
1600  0.14             18.7                2.6                1941              9.5             15831
3200  0.07             33.1                2.4                1003             8.7             15832
