JUan,
Despite your reply to me regarding this bug having been fixed in the transition from v1.4.x to 1.5.0, I am still not able to get the spinBox entries to align to the middle of a suitably sized spinBox control.
I am copying a code snippet to show you the area in my deBayer code where you have already had some input. Am I missing something?
// add SpinBoxes and CheckBoxes, to allow the user to describe the location, order and orientation of the CFA
// set a minimum width for the offset spinBoxes
var XYspinBoxWidth = 15 * this.font.width ("0");
// add a new label for the X-offset SpinBox
this.CFAxOffset_Label = new Label( this );
this.CFAxOffset_Label.text = "CFA X-Offset : ";
this.CFAxOffset_Label.minWidth = labelWidth1;
this.CFAxOffset_Label.textAlignment = TextAlign_Right|TextAlign_VertCenter;
this.CFAxOffset_Label.toolTip = "Enter an X-offset to be applied to the CFA";
// add a new SpinBox to establish the X-offset of the CFA
this.CFAxOffset_SpinBox = new SpinBox( this );
this.CFAxOffset_SpinBox.minValue = 0;
this.CFAxOffset_SpinBox.maxValue = 1;
this.CFAxOffset_SpinBox.stepSize = 1;
this.CFAxOffset_SpinBox.value = globalData.CFAcolOffset;
// ##Note## : There is a bug in v1.4x (i.e, in Qt 4.4) that prevents the following statement from working
// i.e. it is not possible to 'centre-align' a value within a spinBox
// ##Query## : HAVING NOW TESTED THIS ON v1.5, THE 'bug' STILL SEEMS TO BE PRESENT. CHECK WITH JUAN
this.CFAxOffset_SpinBox.textAlignment = TextAlign_Center|TextAlign_VertCenter; // v1.5 onwards ONLY (SEE ABOVE)
this.CFAxOffset_SpinBox.minWidth = XYspinBoxWidth;
// ##Note## : the spin boxes must be made larger manually when a suffix is used because PI does not compute their
// widths correctly (a bug-fix scheduled for PI v1.6, BTW!). The current fix is as per <spinBox.minWidth>, above
this.CFAxOffset_SpinBox.suffix = " pixel(s)";
// allow the spinBox to 'wrap round' from min value to max, and vice versa
this.CFAxOffset_SpinBox.wrapping = true;
this.CFAxOffset_SpinBox.toolTip = "Enter an X-offset to be applied to the CFA";
// create a function to respond whenever the SpinBox is changed
this.CFAxOffset_SpinBox.onValueUpdated = function( index )
globalData.CFAcolOffset = index;
generate_workingCFApixelGrid();
this.dialog.CFACell00_Label.text = workingCFApixelGrid[0][0];
this.dialog.CFACell01_Label.text = workingCFApixelGrid[0][1];
this.dialog.CFACell10_Label.text = workingCFApixelGrid[1][0];
this.dialog.CFACell11_Label.text = workingCFApixelGrid[1][1];
this.dialog.CFACell20_Label.text = workingCFApixelGrid[2][0];
this.dialog.CFACell21_Label.text = workingCFApixelGrid[2][1];
this.dialog.CFACell30_Label.text = workingCFApixelGrid[3][0];
this.dialog.CFACell31_Label.text = workingCFApixelGrid[3][1];
this.CFAx_Sizer = new HorizontalSizer;
this.CFAx_Sizer.spacing = 8;
this.CFAx_Sizer.margin = 4;
this.CFAx_Sizer.add(this.CFAxOffset_Label);
this.CFAx_Sizer.add(this.CFAxOffset_SpinBox);
this.CFAx_Sizer.addStretch();
// . . . . . etc.
