Author Topic: Photometric Calibration - Failure to plate solve image  (Read 1592 times)
Offline wkrispler
« on: 2017 December 03 10:24:06 »
whenever I try to use Photometric calibration I receive the error message "Failure to plate solve image". When I try it with the script "ImageSolver" with exactly the same
parameters Plate solving works.
If I use PhotometricCalibration right after I run the Script ImageSolver it works.
A friend of mine experiences exactly the same issue.
Any ideas? I would like to run Photometric Calibration without running ImageSolver before.
Thank you,
Wolfgang
Offline Andres.Pozo
Re: Photometric Calibration - Failure to plate solve image
« Reply #1 on: 2017 December 03 10:47:28 »
Why? PCC uses ImageSolver to solve the image but ImageSolver gives more parameters. Also, if you solve the image with ImageSolver then you can run/undo PCC many times to test different options without having to solve the image again. If you let PCC to solve the image, when you undo and run PCC again the image is solved again.
Offline wkrispler
« Reply #2 on: 2017 December 03 11:28:29 »
Problem solved!
I had to check the boxes "Force Plate Solving" and "Ignore Metadata". Then it works.
With these 2 boxes unchecked it does not work in my case
Offline Warhen
    • Billions and Billions
« Reply #3 on: 2017 December 09 16:01:54 »
AndrĂ©s, Thank you for your fine scripts! I've dug in deeper and will cover most of them in the second edition of my book.
Best always, Warren
Warren A. Keller
www.ip4ap.com
Offline Warhen
« Reply #4 on: 2019 October 06 12:45:52 »
W Krispler- forgot about this! I must have these enabled as well! Thanks!
Best always, Warren
Warren A. Keller
www.ip4ap.com
