Sadly all the images were assigned to the rubbish bin and filed under the heading "make sure optics are clean before use" I had used flats but they were unable to fix the smudge. The problem was that there was some mildew on the focal reducer.
So here is my astrophotography tip # 35. If you live in a tropical area and dampness is an issue, then every couple of months place optics in direct sunlight. Any mildew will be killed off by sunlight.
Look up
John
