www.pixinsight.com
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
https://pixinsight.com/forum/
News:
Home
Help
Search
Login
Register
PixInsight Forum (historical)
PixInsight
General
Color Mottle
« previous
next »
Print
Pages: [
1
Author
Topic: Color Mottle (Read 2305 times)
jimwaters
Member
Color Mottle
on:
2017 November 14 17:14:05 »
I have old CR2 data that I want to reprocess with PI. For most of this data I didn’t do dithering. Is there an effective way to reduce color mottle? I have tried to use TGVDenoise and other stuff without much success.
Logged
Alejandro Tombolini
PTeam Member
PixInsight Jedi
Re: Color Mottle
Reply #1 on:
2017 November 14 17:22:21 »
ACDNR
could be a good choice. See
this
processing example that may help.
If you can share a screen shot of the problem may be easy to identify other solution.
Saludos,
Alejandro.
Logged
jimwaters
Member
Re: Color Mottle
Reply #2 on:
2017 November 14 20:44:14 »
Thanks for the help. I will check out ACDNR tonight.
Logged
the Elf
Newcomer
Re: Color Mottle
Reply #3 on:
2017 November 15 11:23:24 »
I apply an inverted lumince mask to my data, use a moderate set of paramters in MultiscaleLinearTransform for the luminace noise (Target RGB/K) and then with the mask still applied an agressive setting even on higher layers with Target "Chrominance (restore CIE Y)". Find my "tutorial" here and have a look at the screenshots if this is similar to your challenge:
https://www.cloudynights.com/topic/598277-help-for-beginners-m51-pi-postproc-workflow-screenshots-and-data/
Honest feedback is apprechiated!
Logged
jimwaters
Member
Re: Color Mottle
Reply #4 on:
2017 November 15 14:58:16 »
Thanks..!
Logged
Print
Pages: [
1
« previous
next »
PixInsight
General
Color Mottle
