Hello gurus,
It's been a while
Been focussing on observing visually but ysterday the bug struck me again and I had a go at imaging a wide field M52 and I've been trying very hard to get the images stacked but PI is being a little bit stubborn (I myself am of course innocent
I followed the howto in
http://www.lightvortexastronomy.com/tutorial-pre-processing-calibrating-and-stacking-images-in-pixinsight.html and the Star Alignment procedure keeps telling me that it can't find enough star matches, though it initially finds >2000 stars. I tried relaxing the RANSAC parameters and found a hint to change the descriptor type to triangles in Star Matching but none of this helped. I used a ZenithStar 80 on a Star Adventurer, which -I know- is pushing it, but iirc, I have been able to stack worse data.
I uploaded two of my corrected calibrated and debayered images to wetransfer, maybe someone can see what I'm doing wrong. If it's not enough, I can upload the entire data set. The first image is the one I'm using as reference image.
https://we.tl/5K4UExnUQKI used a superbias out of 29 biases, 29 darks and 15 flats.
