Author Topic: Master files or list of files  (Read 2063 times)
Offline Ken_nneth
« on: 2017 November 04 23:05:22 »
I can’t see any area dedicated to newbie questions so I’ll just post here.
Is it better to use Master files or list of files for calibration? (Eks. Master dark or list of darks)
And what is the difference?
Celestron Edge HD 8 / SkyWatcher Black Diamond ED80
Celestron f7 Reducer?
Sky-Watcher AZ-EQ6 GT
QHY Polemaster
Guiding - ?ZWO OAG - Lodestar X2
?ASI1600 mono cooled, ZWO 7 pos. 32mm filter wheel, Baader LRGB+-Ha filters
SGP, PixInsight, PHD2, Polemaster
Offline Geoff
Re: Master files or list of files
« Reply #1 on: 2017 November 04 23:54:40 »
No difference. If you use a list in batch preprocessing it will generate a master dark, (which takes time) and then it will use the master dark.  If you then want to calibrate a different batch of images taken under the same conditions, use the master dark.
Personally i prefer to generate all my masters (bias, dark and flat) and then use these to calibrate my lights.
Don't panic! (Douglas Adams)
Offline Ken_nneth
« Reply #2 on: 2017 November 05 00:53:15 »
Thanks Geoff :)
QHY Polemaster
