Author Topic: Unable to start PixInsight on Linux system [SOLVED]  (Read 2105 times)
Offline Googaliser
« on: 2017 October 29 22:06:02 »
Hi Everyone,
Have been using PixInsight for a while now in a Windows 10 environment - never any issues.
Am curious to explore Linux, attracted to the reported performance gains in PixInsight. I have tried installing the latest releases of both Ubuntu and Fedora. Installation goes fine - Icon appears under programs - but nothing when I execute in either environment. I do not know enough about Linux to start probing around trying to find missing libraries. I followed a similar post from a month ago where an experienced used was able to get it working. I spent several hours (into the early hours of the morning - if that sounds familiar with this hobby...) trying to replicate their steps but to no avail. libz.so.1 was one of the problem files.
Similar post: https://pixinsight.com/forum/index.php?topic=10718.0
Since I am distro agnostic - if there is a distro where it installs as advertised - I would be grateful for tips. I have tried Ubuntu 17.10 and Fedora Workstation 26.
I love PixInsight and all my energies have gone into learning it - I just don't have the bandwidth at present to learn Linux too and desperately would like a plug-n-play solution.
Best regards to all, Marc
« Last Edit: 2017 November 02 03:43:21 by Googaliser »
Offline Googaliser
Re: Unable to start PixInsight on Linux system
« Reply #1 on: 2017 November 01 21:40:02 »
Hi - is anybody able to assist ? Thank you...
Offline jpaana
« Reply #2 on: 2017 November 02 01:19:51 »
On Ubuntu 17.10 I had to rename both libz.so.1 and libstdc++.so.6 to get it to work.
Offline Googaliser
« Reply #3 on: 2017 November 02 01:28:10 »
Interesting - think those were the problem ones for me. Would you be able to show the instructions you used to achieve this ?
Much appreciated
Offline jpaana
« Reply #4 on: 2017 November 02 01:36:47 »
Just go to /opt/PixInsight/bin/lib directory and rename files libz.so.1 and libstdc++.so.6 to something else (or deleting the altogether works too, but I usually just add .bak to remember I've done something) either with a file manager or in terminal like this (directory is owned by root so have to use sudo):
cd /opt/PixInsight/bin/lib
sudo mv libz.so.1 libz.so.1.bak
sudo mv libstdc++.so.6 libstdc++.so.6.bak
Offline Googaliser
Re: Unable to start PixInsight on Linux system [SOLVED]
« Reply #5 on: 2017 November 02 03:42:33 »
Solved ! Thank you so much... am gaining confidence with Fedora so was less daunting.
Performance increase is astounding - both the CPU and Swap performances have increased by 100% versus windows 10 on a twin xeon rig. Worth learning Linux for that kind of boost !
Offline JFKoenig
« Reply #6 on: 2018 September 09 02:04:54 »
same problem and same solution (jpaana) on ubuntu 18.04 64bit
thank you!
Offline deanj
    • Dean's Astrophoto Website
« Reply #7 on: 2019 June 22 12:58:21 »
Need a little help here with a new Ubuntu installation.  The library changes didn't work.  The libz.so.1 file or symbolic link was not in the /opt/PixInsight/bin/lib/ directory and renaming the libstdc++.so.6 symbolic link had no apparent effect.  When I go back to the ~/HOME/pi-install/Pixinsight/bin/ and then execute the ./PixInsight command I get "./PixInsight: error while loading shared libraries: libssl.so.10: cannot open shared object file: No such file or directory
So, how do I get it to work?
Also, the instructions on the PixInsight Software DIstribution page led me to believe that a desktop icon would be installed when I ran the ./installer.  No such luck here.
Lastly, the FAQ pages indicate that I need to put a copy of my license document in $HOME/.PixInsight but there isn't any such file...
Help, please.  Thanks.
Dean Jacobsen
Offline deanj
« Reply #8 on: 2019 June 22 13:04:14 »
Forgot to mention that I am using Ubuntu 18.04
Dean Jacobsen
Offline deanj
« Reply #9 on: 2019 June 22 21:49:46 »
OK, never mind.  Further research found the answer: https://pixinsight.com/forum/index.php?topic=10489.0
Dean Jacobsen
