Author Topic: Sandbox doesn't build  (Read 3677 times)
« on: 2009 May 19 07:14:04 »
Hi Juan,
looks like you have __PCL_WINDOWS defined in your environment as this needs to be added to the VC project before it will build. The debug config also doesn't include the PCL library reference. The release version has the library name but not PCLDIR\lib in its library path. Let me see if I can clean up the project and upload it for you.
Re: Sandbox doesn't build
« Reply #1 on: 2009 May 22 03:17:53 »
Hi Sander,
OK, I'd appreciate if you can do the cleaning work (if possible, of course, don't feel obliged at all!). The Sandbox module is important for PCL beginners. By the way, do you like it as it is now, or do you think I should add/remove something? (keep in mind it should remain simple).
« Reply #2 on: 2009 May 22 06:01:26 »
I think the sandbox is fine. It barely scratches the surface of course but what can you do? Add too much code and it gets even more confusing. Take stuff away and there's nothing to learn. I think that getting it to build properly should be step #1 :)
