Author Topic: Star Alignment  (Read 3552 times)
Offline Jack Harvey
Star Alignment
« on: 2009 May 18 13:54:11 »
WHen running a stack of floating point images to register as the prgram comes to each frame I get the Fits Floating Point Option window that requies me so select "ok" before it will process this frame and move on to the next - at which time I get the window again.  SO one much "ok" each registration frame rescale option.  Sure wold be nice to be able to indicate "ok" for all images in the stack and just have the program run thru the whole batch.
Jack Harvey, PTeam Member
Offline Fco. Bosch
Re: Star Alignment
« Reply #1 on: 2009 May 18 15:11:57 »
perhaps a "save all" option, that could save all the actual views, with the parameters selected
Fco. Bosch
Re: Star Alignment
« Reply #2 on: 2009 May 18 15:25:49 »
Hi Jack,
Go to Format Explorer, select the FITS format, and click on Edit Preferences (bottom right, or double click the FITS item which does the same). On the dialog box, select: Floating Point Out Of Range Policy > How to proceed > Normalize to the default input range. By default this option is "Ask on out-of-range read values".
Offline Jack Harvey
Re: Star Alignment
« Reply #3 on: 2009 May 18 15:40:55 »
I figured there was a seting somewhere - just did not find it with my poking around.  Thanks
