Author Topic: Filename icons desappered after update to 01.08.05.1353  (Read 1294 times)
Offline Thomas
« on: 2017 October 21 05:58:59 »
Since I have updated PI to version  01.08.05.1353 on two different computers (de-installed the old and re-installed the new version) the "blue PI icons" which are normally shown with the .xisf filenames (a.e. if you chose File-> Open to select files  or in the windows explorer) are gone . This happens after I opened and closed PI a few times.
Not sure if this was already reported .
Thomas
Offline Andres.Pozo
Re: Filename icons desappered after update to 01.08.05.1353
« Reply #1 on: 2017 October 22 01:36:10 »
A few times  ;). Use the search function.
I think it is related to letting PI launch an instance from the installer (which is a really bad idea), but I'm not sure.
« Reply #2 on: 2017 October 23 01:09:43 »
Agreed. The Windows installer packages won't include an option to launch the application since the next version.
Offline Thomas
« Reply #3 on: 2017 October 30 09:30:59 »
Thanks guys,
I de- and re-installed it, and did not launching PI direct from the installer app,  for now it seems to work well.
Thomas
Offline Thomas
« Reply #4 on: 2018 June 01 04:41:37 »
The problem happens from time to time, even after fresh PI installation Win 7/64 Bit .
I found a workaround to manually set the PI desktop Icon path ( https://pixinsight.com/forum/index.php?topic=11380.0 )
Is there any workaround to set / repair the PI filename icons also ?
Thomas
