Author Topic: Harry's video tutorials  (Read 252589 times)
Offline DB
Re: Harry's video tutorials
« Reply #135 on: 2010 December 31 14:43:21 »
Hi Harry
I am using Equinox to image and use it for dark subtraction and LRGB conversion from a color camera.  Any advice about pre-processing of images, and automating the steps from channel extraction to producing a stacked image may be useful.
Many thanks and all the best for the New Year.
regards
David
Offline Harry page
« Reply #136 on: 2011 January 01 01:37:09 »
I am not heard of equinox  >:D I presume its a capture program with some calibration capabilities  ;)
So you need to decided what you want to do in pixinsight if you want to calibrate your images in equinox and bring them into pixinsight you can just the registration and integration as per my video's :D
I suspect you are using a DSLR and if you are i would read this http://pixinsight.com/forum/index.php?topic=2570.0 done by mr Astropixel  ;D
I do not quite understand a couple of things 1 ) a OSC camera creates RGB images not LRGB images  2) channel extraction is easy but why do you want to do it  ;) there is no reason in pI to process each channel separately
Have a good new year
Kind regards Harry
Harry Page
Offline DB
« Reply #137 on: 2011 January 03 03:32:28 »
Hi harry
I am using an SBIG XCM2000 one shot color camera.  Equinox come bundled with it (for Macs) and controls the camera and G11 through the autoguide port.  The process is to capture the images, dark subtract and then convert to LRGB in equinox.  The individual color channel files are then combined in Image Integration in PixInsight and then move on from there.  I'd be happy to do everything in PixInsight after capturing the image.
regards
David
Offline Harry page
« Reply #138 on: 2011 January 03 09:53:19 »
I see that you are subtacting darks  O:) are you using flats yet ?
I find it strange that the image files are saved in seperate files , I can not see the reason for this ,  you also keep using the lum word is are you getting a lum file as well ?
I am working on a calibration video now and should have it ready soon
Regards Harry
Harry Page
Offline DB
« Reply #139 on: 2011 January 03 14:02:18 »
I do subtract flats as well (but not always if I am being lazy).  As I understand it the LRGB files are saved separately, perhaps something to do with removing the Bader mask.  It certainly would be easier if the single file could be handled but would that allow processing of the luminosity separate from color?  Is there any tutorial on Pixinsight and single shot color cameras?
regards
David
Offline Harry page
« Reply #140 on: 2011 January 03 14:09:37 »
I think the lum you are getting is a seudo lum and will bring no new info to the party  ;Dand because of this there is nothing to be gained by processing the lum seperatley from the RGB
All of my tut vids from the newbie section are from a OSC camera ( sxvf m25 )  O:)
Regards Harry
Harry Page
Offline DB
« Reply #141 on: 2011 January 03 20:24:29 »
Sorry to be slow about this.  To be clear, with a OSC camera image, you simply 1) dark/flat subtract, 2) star align and 3) stack images with Image Integration?
regards
David
Offline Harry page
« Reply #142 on: 2011 January 04 07:38:59 »
Yes as simple as that  :angel:
Harry
regards
David
Harry Page
Offline Josh Lake
« Reply #143 on: 2011 February 12 19:42:23 »
Hi, Harry,
Because of your tutorials, I've really progressed with learning PI over the last month or so. One thing I see a fair bit is use of the Atrous Wavelet tool and I can see that it's very powerful for doing multiple things, even for creating masks. Do I have any hope of another great tutorial from the Astroshed?
Thanks. If not, no worries, you've been amazingly helpful.
Offline Harry page
« Reply #144 on: 2011 February 13 09:34:03 »
This was on the list to do at christmas  ;D
Just been so short of time latley , but I will do it soon  :D
Harry
Harry Page
Offline DB
« Reply #145 on: 2011 March 06 01:42:06 »
regards
David
Hi Harry
I wonder if you could advise a couple of things about the OSC workflow. Presumably the above sequence also requires a 'de-bayer' step to remove the grid.  Is it possible to do this batchwise? is there anything else in the sequence needed?  Lastly, do you know if there is any support material on one shot camera workflows?
regards
David
Offline Harry page
« Reply #146 on: 2011 March 06 02:00:33 »
Yes it should be
1) Dark /flat application
2) debayer
3) Alignment
4) Image integration
There is also a Batch debayer tool under scripts , also there is the new script to do all this in one go  ;D
All my basic videos were created using a OSC camera  8) and even if you were using a mono camera and created a RGB this way there is no difference in processing
Regards Harry
Harry Page
Offline DB
« Reply #147 on: 2011 March 08 02:42:13 »
Excellent thanks.  I found that the 'superpixel' setting was required.  That seemed to work OK.
Another basic question - when it is debayered and integrated, it is recorded as a RGB file, yet it appears greyscale. Just an image (M83) with no color?
Offline Harry page
« Reply #148 on: 2011 May 15 00:40:32 »
I did a quick process of a lum image to go with the RGB one I did a while ago , showing how you combine them as well
Includes a look at my new favorite tool the LHE
http://www.harrysastroshed.com/Part2%20LRGB.html
Regards Harry
Harry Page
« Reply #149 on: 2011 May 15 04:59:40 »
Another great tutorial! Thanks Harry! Even a seasoned PI user can still learn something. Will try the LHE tool as soon as possible 8).
One remark though: I would recommend to do a FormatConversion to f32 as a first step (you are using i16). In particular during the histogram stretches, I tend to see posterization when doing this in i16 space with my DSLR photos.
