Author Topic: BPP Reuse  (Read 2107 times)
Offline tloebl
BPP Reuse
« on: 2017 October 13 06:02:32 »
Could someone please remind me which box in BPP global options needs to be checked in order to be able to reuse the script without re-entering all the subs?
Offline John_Gill
Re: BPP Reuse
« Reply #1 on: 2017 October 13 07:10:11 »
Setup your BPP with all the files etc etc, then drag and drop the "triangle" from the bottom left corner of the process window onto the desktop.  Now you can execute the process and if you don't like the results, double click on the newly created icon and you can make changes to the setting and re-execute the process.  This works for most, if not all processes.
Look up
John
APM 107/700 apo on CGX mount
ZWO Optics - Autoguiding
ZWO1600mm and filters
Offline tloebl
Re: BPP Reuse
« Reply #2 on: 2017 October 13 08:08:40 »
Thanks John...
Offline tloebl
Re: BPP Reuse
« Reply #3 on: 2017 October 13 08:15:36 »
John, that does not save the information within BPP, it only brings up a blank one. I seem to recall one of the global options needs to be checked...
Offline tloebl
Re: BPP Reuse
« Reply #4 on: 2017 October 13 08:18:57 »
Found it...looks like "Export Calibration Files" must be checked for the entries to be saved for recovery.
