Author Topic: Error Registering light Frames  (Read 2483 times)
Offline philh
« on: 2017 October 12 06:29:04 »
Hi Im trying  out Pixinisght for the first time. i tried to stack using the script Batch Processing . I had just lights and dark and got a warning message saying Error registering light frames.
Can anyone give me some info on what i should do to avoid this ?
Offline RickS
Re: Error Registering light Frames
« Reply #1 on: 2017 October 15 00:22:30 »
Have you checked out the light frames with the Blink process to see if they all look OK?  If that doesn't give any hints then try running BPP with calibrate only and then Blink the calibrated lights.  If there is something going wrong with the calibration then that may be obvious.
Rick.
Offline Warhen
    • Billions and Billions
« Reply #2 on: 2017 October 20 04:56:04 »
What's the nature of the data? The script generally does a fabulous job of registering about anything. But, it does require six matching pairs of stars to succeed. If the data is a high-res field with not enough stars, or a narrowband field with insufficient star contribution, it can fail, where the StarAlignment process with its greater control, will succeed.
Best always, Warren
Warren A. Keller
www.ip4ap.com
Offline gaprunella
« Reply #3 on: 2018 February 12 05:57:58 »
Hello, For the first time ever I am unable to star align my lights.  I have 3 hours of data and can only stack 10 images.  The field of view is small with not many stars showing up.  I've blinked every file and they all look good with the dither being the only  movement.  I've attached a screen shot of the photo with some of the error.  I've calibrated the files with bias, dark and flat.  I used the subselector script to eliminate the bad.  I've increased the  RANSAC to the max starting with 6.  I've decreased the Log sensitivity also.  I've tried aligning both original files, calibrated files even tried eliminating the various master calibrated files one at a time.  I'm not sure what else to try.  Does anyone have any advice?
Camera ZWO ASI178MC-Cool with Explorer Scientific ED102
Thank you
