Recently, I've been getting an Error during ImageIntegration. I've been following the same process I've used dozens of times, but about a week or two ago this started happening. It doesn't happen with all captures, just some of them. I've attached a screenshot of the issue and want to know if there's anything I can look into that will give me an idea of what the problem is. I'm completely up-to-date with Pixinsight.
Thanks, in advance, for any help you can offer.
UPDATE: I experimented with several things and got one of them to work. Under the Pixel Rejection (1) section, I had been setting "Normalization" to "Local Normalization," because I'm using Local Normalization data. For the a that's been failing, I changed that to "Scale + Zero Offset" and I was able to successfully run ImageIntegration. So the question is: "When using Local Normalization data files, what is the proper setting for this parameter?"
