Author Topic: Sony a7ii arw files  (Read 2493 times)
Offline SDB777
Sony a7ii arw files
« on: 2017 September 24 13:37:07 »
I'm guessing this hasn't been addressed with a fix?
I've tried all the 'this worked for me' suggestions(found from searching 'sony are files')....
Been trying for the last five hours to get something other then a triple image nightmare that looks nothing like what it should....disappointed.  Sure wanted something other then DSS3.3.4 and PS CC(I hope this works). And I'm sure not liking the Canon images I've had to deal with after looking at the Sony images.
Scott (there goes my 45 day trial period) B
Offline sharkmelley
Re: Sony a7ii arw files
« Reply #1 on: 2017 September 24 14:29:36 »
Possibly your problem is related to this one for Sony files in uncompressed format:
https://www.cloudynights.com/topic/590006-latest-dss-334-still-cannot-work-with-sony-raw-files/
I actually looked into the DCRAW code (which PixInsight uses) and found that it doesn't recognise this newer uncompressed format.
For a long term solution send example uncompressed files to Dave Coffin (the author of DCRAW) so he can support them in the future.
In the short term, either use the usual Sony compressed format for astrophotography or convert your uncompressed raw files to something that PixInsight recognises.
Mark
[P.S. I use a Sony A7S for astro and have never experienced any limitations caused by the compression. Unlike the "star eater" spatial filtering which is a HUGE issue for me]
« Last Edit: 2017 September 24 14:54:49 by sharkmelley »
Takahashi Epsilon 180ED
H-alpha modified Sony A7S
Offline SDB777
« Reply #2 on: 2017 September 25 04:14:50 »
Mark
Thanks for the fast reply!
I'll check out the 'cloudy nights link' in a moment.
I'll also look into DCRAW, which image would he want? Just the 3+minute exposures?
I checked the format used, and it is not the 'uncompressed', although those definitely work on the 'other platform'....for whatever reason I had actually switched back to the 'regular' compressed files at some point.  If I do decide to use the 'uncompressed files', what/where do I need to go to convert them(what do you use)??
Thanks again Mark!  I heard rumors awhile back that the 'star eater' had a partial 'fix', but apparently it is only on the green channel....not sure I'd even call that a halfway fix.  Clear skies!!
Scott (off to the links for some reading) B
