www.pixinsight.com
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
https://pixinsight.com/forum/
News:
Home
Help
Search
Login
Register
PixInsight Forum (historical)
PixInsight
General
Overlay two images
« previous
next »
Print
Pages: [
1
Author
Topic: Overlay two images (Read 2745 times)
remi@astrorl.ca
Newcomer
Overlay two images
on:
2017 September 22 14:28:34 »
I would like to combine a Luminance layer with an Ha layer. I normally do this in PhotoShop using layers and overlay. How can I do the equivalent in PI? Can it be done in PixelMath and if yes, what would be the equation?
Thanks in advance.
Remi
Logged
avastro
PixInsight Addict
Re: Overlay two images
Reply #1 on:
2017 September 23 00:46:27 »
Remi, search the forum for combining Ha with RGB, you will find many approach, like this one.
https://pixinsight.com/forum/index.php?topic=11526.msg71476#msg71476
cheers
Antoine
Logged
Antoine
Lentin Observatory
oldwexi
PixInsight Guru
Reply #2 on:
2017 September 23 07:04:50 »
Hi Remi!
If you have Luminance image "L" and H-Alpha image "Ha"
You can mix mix/overlay these 2 mono images/layers with different PixelMath expressions:
The simplest one is:
L + Ha
including also percentages: 70% L and 30% Ha the expression in PixelMath is:
(L*0.7) + ( Ha*0.3)
etc... etc...
There should be also in your installation the script "Blend" selectable. (Utilities/Blend)
Where you find more possibilites to overlay images as you know from the astropaintings program,
without needing PixelMath knowledge.
In addition let me mention:
to mix Lum with Ha does only make sense if you stay in mono!!
Mixing the Lum+Ha result with RGB results in wrong/pink Ha colors as Lum gets also into Green and Blue channel.
Therefore this results in typically pink HA areas...
Ha should never be imbeddeed into L when doing LRGB!
Ha should be imbedded into the R channel.
Gerald
Logged
mmirot
PixInsight Padawan
Reply #3 on:
2017 September 23 08:11:04 »
Blend is not in the current release. Still works? Have a link
Max
Logged
oldwexi
PixInsight Guru
Reply #4 on:
2017 September 23 08:27:40 »
Max!
Give me a few minutes, will come up with the private link.
On my installation WIN 7 Prof + newest PI it works.
Gerald
P.S.: if you have added in
Manage Update Repositories
http://pixinsight.com.ar/repository/
it should be available.
Logged
oldwexi
PixInsight Guru
Reply #5 on:
2017 September 23 08:40:17 »
Hi Max!
If you click
you can download manually the zipped
BlendStarMask script.
Gerald
Logged
Print
Pages: [
1
« previous
next »
PixInsight
General
Overlay two images
