Author Topic: "Invalid out format" message in PCC PI 1.8.5.1353  (Read 1699 times)
Offline Yuriy Toropin
« on: 2017 September 16 12:51:06 »
If carefully go through Process Console log after run of PhotometricColorCalibration, I will see "Invalid out format" message.
To be exact, 3 of them after photometry of each RGB channel.
is it intended?
Calculating photometry: Processed 17401 stars in 2.022000 seconds
Astrometric error: RMSx=0.0377" RMSy=0.0359" RMS=0.0521"
Writing output file: C:/Users/yuriy/AppData/Local/Temp/PCC_R_VVRG853MFGI8.csv
Invalid out format
Processing image C:/Users/yuriy/AppData/Local/Temp/PCC_G_FALQHI9LMLEN.xisf
Reading image:
Loading image: w=4948 h=3280 n=1 Gray UInt16
9 image properties
122 FITS keyword(s) extracted.
Load controlpoints
Loaded 88 control points
Reference image: PCC_G_FALQHI9LMLEN
1 view(s)
17726 star(s)
17364 PSF fittings
Found 60 stars with invalid position
Reference stars: 17364
Validating reference stars
Stars with problems: 8394
Calculating image noise: sigma=24.671 count=6.15% layers=3
Multiscale median transform: done
Multiscale reconstruction: done
Normalizing sample values: done
Aperture Photometry:
  Aperture: 5.000000 px
  Image resolution: 7.564051 sec/px
Calculating photometry: Processed 17364 stars in 1.817000 seconds
Astrometric error: RMSx=0.0341" RMSy=0.0346" RMS=0.0486"
Writing output file: C:/Users/yuriy/AppData/Local/Temp/PCC_G_FALQHI9LMLEN.csv
Invalid out format
Re: "Invalid out format" message in PCC PI 1.8.5.1353
« Reply #1 on: 2017 September 22 01:20:09 »
Hi Yuriy,
This is a purely cosmetic issue without further consequences. We'll try to fix it in the next version.
On a side note, your application of PCC is probably using an excessive amount of reference stars, which include a lot of outliers, as you can see on the graphs. Why are you disabling the automatic limit magnitude feature?
