Author Topic: Problem running PI on Ubuntu with dual boot Windows 10  (Read 2077 times)
Offline joelshort
    • Buckeyestargazer.net
« on: 2017 September 13 15:10:41 »
I've recently been experimenting with PI on Ubuntu in a dual boot configuration with Windows 10 (see specs below).  I have each OS installed on two separate SSDs.  The problem is that in Ubuntu I can run one benchmark but half way through the second benchmark the computer locks and I get a black screen.  My first thought was that something was overheating so I kept an eye on the temps and nothing was off.  And this doesn't happen in Windows.
When I created the Ubuntu partition I set it up with 30GB root, 80GB home and 30GB swap.  I thought that would be plenty.
Anyone have any idea what could be causing this?
Joel Short
www.buckeyestargazer.net
Offline joelshort
Re: Problem running PI on Ubuntu with dual boot Windows 10
« Reply #1 on: 2017 September 13 17:55:21 »
I think I found the problem.  This is a new PC to me and the previous owner had overclocked the CPU and RAM (with a water cooler).  I reset all everything to stock speeds and have run several benchmarks without problems.  What I don't understand is why this only happens in Ubuntu and not in Windows since both are using the same hardware.
Joel Short
