Author Topic: Optimum Disk Drive Config - RAID 0 vs Separate  (Read 2245 times)
Offline SeattleStarGazer
« on: 2017 September 04 12:46:52 »
I'm working on configuring a Lenovo Thinkpad P71 as graphics workstation with 2 SSDs and 1 HDD. Software like Photoshop, Premiere, but also PI. From reading other posts on PI, am I correct in assuming keeping the SSDs separate and not a RAID 0 array would be optimum by allowing swap files on separate physical drives? Also, should I include the HDD on list of swap directories?
Second, I have a choice of i7 or Xeon processor. Does one really make a difference for PI?
Wayne
Offline John_Gill
Re: Optimum Disk Drive Config - RAID 0 vs Separate
« Reply #1 on: 2017 September 04 23:31:43 »
A xeon processor is a bigger, better, faster processor.  A raid will give a little bit of an improvement in the disk performance for HDD's, but will help greatly in the event of a disk failure (sometimes).  Using a SDD for the swap file(s) would improve performance and I would load the current project onto the SDD.  I don't think you will benefit from doing a raid on the SDDs.
Hope this helps.
Look up
John
APM 107/700 apo on CGX mount
ZWO Optics - Autoguiding
ZWO1600mm and filters
Offline bvalente
« Reply #2 on: 2017 September 06 12:25:09 »
agree on ram swap drives, you might look at adding 1 or 2 of those. they sped up my PI install quite a bit
B
