Author Topic: Maximization Limit resets while maximizing image window  (Read 868 times)
Offline jbaetz
since the 1.8.5 update I'm unable to set permanent the maximization limiter to a custom position.
If I change the position and afterwards maximize a image window the limiter resets to it's PI default position and use this position to limit the horizontal size of the image window.
OS: Windows 10 1703
PI: 01.08.05.1353
latest patches were applied.
At the moment the limiter is unusable for me, but I'm the only one with the issue?
Best regards,
Jürgen
Re: Maximization Limit resets while maximizing image window
« Reply #1 on: 2017 August 28 04:46:23 »
Hi Jürgen,
I'll take this into account for the next version, and will try to improve the behavior of the maximization limit during window resize operations.
Well, I would not rate this problem so severely. You can drag the limit as necessary with the mouse in less than a couple of seconds.
Offline jbaetz
« Reply #2 on: 2017 August 30 02:36:57 »
Thank you for answering me and to taking it into account, Juan!
Best regards,
Jürgen
