Author Topic: Bayer Drizzle  (Read 6537 times)
Offline acmalko
Re: Bayer Drizzle
« Reply #15 on: 2018 April 10 00:28:57 »
Thanks for the feedback !
I checked the properties with the view explorer and I can find the CFA path information after Debayer process but not after using the script. I should maybe try to use the "move" output option instead of "copy".
Using the script with the raw CFA files sounds a bit weird to me but I should give it a try.
Yes ! good idea  :D
I'm testing bayer drizzle too but don't want to give up Subframe selector process.
On the other hand, I don't have good results for the moment. Too much green halos around my stars with this method.
Maybe should I try again
VNG debayer vs Drizzle bayer 1:1
« Last Edit: 2018 April 10 02:30:50 by acmalko »
Offline acmalko
Re: Bayer Drizzle
« Reply #16 on: 2018 April 10 02:32:51 »
Unfortunately, it doesn't works. Moving the pictures with subframeselector keep the CFA tags but no weight is visible in the FIT header
Offline Tromat
Re: Bayer Drizzle
« Reply #17 on: 2018 April 10 04:17:35 »
This script is not color sensor friendly  :-\
I tried it on the raw CFA files, it works, but then you lose the CFA pattern information so you have to manually specify the pattern to the debayer process. That's not a big problem but still...
Offline ajniskan
Re: Bayer Drizzle
« Reply #18 on: 2018 April 11 12:07:34 »
There's a known bug in the SubframeSelector script (deleting some fields). The bug is already fixed and available as a processing module at: https://pixinsight.com/forum/index.php?topic=11780.0
That version doesn't delete the CFA fields. From the thread you can find binaries for Windows/Linux/OSX platforms, and if I read correctly, the module will be made an official part of PixInsight in future.
br,
Antti
Imaging with: iOptron CEM25P, TS-Pro 6" RC with Pegasus FocusCube, Altair Astro Hypercam 178C or unmodded Canon 6D. Guiding with SW EvoGuide 50SD, AltairAstro GPcam & PHD2. Control via laptop, huge battery pack & APT/BYE.
Offline acmalko
Re: Bayer Drizzle
« Reply #19 on: 2018 April 12 05:41:11 »
Thanks for the link :)
