Author Topic: DBE/ABE when no Background is visible  (Read 2413 times)
Offline rdryfoos
« on: 2017 August 16 11:43:48 »
If I am imaging a diffuse nebula region with a limited FOV and there is no real background visible--should I use ABE with the normalized box checked?  Or is there a way to use DBE under these conditions?
Rodd
Offline Stu
Re: DBE/ABE when no Background is visible
« Reply #1 on: 2017 August 16 14:12:12 »
I generally use ABE.
Offline aworonow
    • Faint Light Photography
« Reply #2 on: 2017 August 16 15:19:45 »
If there is no background visible (or very little visible, or visible in just a few not-well-distributed areas), then how would one find gradients in the "background?" Don't think it either ABE or DBE can be used.
Alex W
Offline rdryfoos
« Reply #3 on: 2017 August 16 15:25:00 »
That is not what Vicent says--I just forgot what exactly he said.  Besides--gradients are not only in background, and DBE is not only for gradients.
Rodd
Offline llpastro
    • Sonoran Dark Skies
« Reply #4 on: 2017 August 17 07:08:24 »
I probably knew this at one time but have since forgotten.  For what is DBE used besides gradients?
Larry
AP 140 Refractor
SBIG ST-10XME
AP Mach 1 Mount
ATS Portable Pier
Tucson, Arizona
Offline rdryfoos
« Reply #5 on: 2017 August 17 07:19:27 »
Larry
  Well--not sure--but I remember Vicent indicating that you could use DBE JUST in gradient mode, which implies there is another use.  But, gradients transcend the background--color gradients can cross over into high signal areas.  DBE helps with contrast between light and dark areas (dark struvtures and emission areas).
Rodd
