Author Topic: PI Desktop Icon Issue  (Read 2772 times)
Offline llpastro
    • Sonoran Dark Skies
« on: 2017 August 13 07:30:02 »
Since I have upgraded to the latest version, I have lost my nice PI icon.  It now looks like a generic shortcut icon.  Is this true for everyone or do I need to reinstall to get the original icon design back?  The same appearance occurs if I pin it to the task bar.  I am using Win 10.  I can't locate the .exe file to send it as a shortcut to the desktop to see if that changes things.
Larry
AP 140 Refractor
SBIG ST-10XME
AP Mach 1 Mount
ATS Portable Pier
Tucson, Arizona
Offline kwalker
Re: PI Desktop Icon Issue
« Reply #1 on: 2017 August 13 08:13:10 »
I had to do an uninstall and reinstall to get the Icons back.
working for now
Offline llpastro
« Reply #2 on: 2017 August 13 08:29:09 »
Thanks, that solved the problem.
Larry
AP 140 Refractor
SBIG ST-10XME
AP Mach 1 Mount
ATS Portable Pier
Tucson, Arizona
Offline kwalker
« Reply #3 on: 2017 August 14 03:30:30 »
My Icons Disappeared again this morning.
Offline topboxman
    • Peter's Gallery
« Reply #4 on: 2017 August 14 08:49:26 »
Happened to me. Had to re-install PI and the icon is back.
Peter
Offline llpastro
« Reply #5 on: 2017 August 14 16:56:08 »
I have had to reinstall twice now.  Keeping a close eye on the icon to determine when it changes.
Larry Phillips
AP 140 Refractor
SBIG ST-10XME
AP Mach 1 Mount
ATS Portable Pier
Tucson, Arizona
Offline John Massey
« Reply #6 on: 2017 August 14 17:07:21 »
I had the same issue. I resolved by remapping the icon for the shortcut. My install locates the icon in C:\Program Files\PixInsight\bin and so far so good.
Hope that helps!
Offline OldSkyEyes
« Reply #7 on: 2017 August 15 01:15:41 »
I have the same problem, a missing icon symbol, I thought maybe it's a windows7 cache problem, I deleted the cache and I got this icon instead (from the taskbar):
I assume something is wrong with the latest version of the windows install. (1353)
« Reply #8 on: 2017 August 15 02:16:33 »
I have seen this issue on one of our Windows 10 machines. I don't know why this happens. For some reason, Windows suddenly removes the icon associated with the desktop icon and assigns a generic document icon.
The workaround is simple:
- Right click the desktop icon.
- Select Properties.
- Click on Change Icon.... Ignore a "Cannot locate..." error message if it is shown.
- Select "C:\Program Files\PixInsight\bin\PixInsight.ico"
- On the PixInsight Properties window, click OK.
I'll investigate why this happens.
Offline Andres.Pozo
« Reply #9 on: 2017 August 15 05:14:39 »
This has happened also to me a few times in Win10. If it helps, I think all the times that this happened, I had launched PI directly from the installer as Administrator, but I could be wrong.
In any case, I think it is not a good idea to allow to launch any application from the installer if this implies launching it as Administrator.
Andrés.
« Reply #10 on: 2017 August 16 01:33:29 »
I completely agree. The installer is necessarily executed with administrative privileges. When it executes PixInsight, the application inherits the same user settings, which is wrong IMO. I'll remove the "Launch" option from the installer in the next version.
However, this "disappearing icon" issue is being caused by something different. I need to investigate it further.
Offline llpastro
« Reply #11 on: 2017 August 17 07:11:16 »
It has been 3 days now since reinstalling PI for a third time and my icon has not reverted to a generic one.
Larry
AP 140 Refractor
SBIG ST-10XME
AP Mach 1 Mount
ATS Portable Pier
Tucson, Arizona
Offline jliu
« Reply #12 on: 2017 September 03 17:50:50 »
I experienced the same issue under Windows 7 Professional.  Juan's workaround reestablishes the icon.  I'll report whether the fix sticks.
Jack
