Author Topic: LocalNormaliation  (Read 2452 times)
Offline rockwall astro
LocalNormaliation
« on: 2017 August 12 06:50:04 »
I have tried to work with the new LocalNormalization tool using .xsif files that are the output of the star aligngment tool.  These files came from a dslr and are debayered.
Once loaded into LocalNormalization along with a reference image I hit the round global apply button.  It appears to load 2-5 images then locks up.  I have tried on two seperate computers with the same results as well as trying with 20 images then with only 2 images.  What am I doing wrong?
t
thanks
Offline slackingCamel
Re: LocalNormaliation
« Reply #1 on: 2017 August 26 04:39:10 »
i get the same, it locks up after 9 frames for me.
takes my cpu and ram for a ride till i abort it.
« Reply #2 on: 2017 August 26 05:38:45 »
I cannot reproduce this problem with any of our data sets. LocalNormalization works without problems with large sets of > 50 files. Can you upload a set of frames where you are having this problem, so I can test the tool with them?
« Reply #3 on: 2017 August 26 23:24:45 »
my apologies...
it does work, i just needed to step away from the pc for long enough to let it finish. :footinmouth:
Offline John_Gill
« Reply #4 on: 2017 August 27 01:14:06 »
mmmh, you need to be more like a "slacking Camel"  :)
APM 107/700 apo on CGX mount
ZWO Optics - Autoguiding
ZWO1600mm and filters
