Author Topic: Update process faled (after upgrade to 1.8.5)  (Read 1097 times)
Offline federico
  • A brilliant future behind
    • Business site
« on: 2017 August 11 02:20:34 »
Hi all,
I've successfully upgraded pixinsight to 1.08.05. (With CXXABI_1.3.8 problem, solved with export LD_LIBRARY_PATH=./PixInsight/bin/lib solution). OS is Ubuntu 14.04, regularly updated.
After launch, it reports 5 updates available. As usual, PI downloads (5) updates, after exit it asks to install the updates BUT, after restart it says "update process failed", and shows nothing in update LOG.
Any advice?
Federico
Re: Update process faled (after upgrade to 1.8.5)
« Reply #1 on: 2017 August 13 03:07:36 »
Hi Federico,
This problem is easily solved by installing GCC 4.9 or later, or by simply creating a symbolic link. See my answer in this thread:
https://pixinsight.com/forum/index.php?topic=11301.msg70395#msg70395
Let me know if this helps. Obviously, another solution is upgrading from Ubuntu 14 to the latest version, but you already know this :)
