Author Topic: FIT files  (Read 2595 times)
Offline BramMeijer
FIT files
« on: 2017 August 09 03:52:19 »
Hello,
I was trying to open some FIT files in the batch pp script, but all my fit files won't open anymore...
They could be opened a while ago, any suggestions?
Cheers
Offline BramMeijer
Re: FIT files
« Reply #1 on: 2017 August 09 03:55:11 »
PCL FITS Format Support: Unable to open FITS file:
/Users/brammeijer/Documents/Foto's 6D/QHY9/Flats/Flats O3/Flat/flat nb_1,33sec_1x1_OIII_frame1.fit
CFITSIO error message stack:
01 : Extension doesn't start with SIMPLE or XTENSION keyword. (ffrhdu)
02 : 3Èc?#? ?|<^
½ZÉçÅý%uÌÌa6? ÅdmÁ¶ÇËa9øqj«ÄúÍ??U)ðÃ4ãl¨??   xÂ?+ÌE®$I4?&ä7Ȫ
03 : ffopen could not interpret primary array header of file:
04 : /Users/brammeijer/Documents/Foto's 6D/QHY9/Flats/Flats O3/Flat/flat nb_1,33sec_1
05 : x1_OIII_frame1.fit
06 : This does not look like a FITS file.
This is the message i recieve.
Re: FIT files
« Reply #2 on: 2017 August 09 03:59:11 »
Please use the FITS File Verifier service by NASA/HEASARC to check if this is a valid FITS file.
Offline BramMeijer
Re: FIT files
« Reply #3 on: 2017 August 09 04:03:15 »
I will try that option.
But i never had issues opening those same fit files before.
ty, Bram
Offline BramMeijer
Re: FIT files
« Reply #4 on: 2017 August 09 04:04:16 »
File name:  Flats qhy9 tak106 HaLRGB_7sec_1x1_HA_frame1.fit
                                           Run Number 21573
              fitsverify 4.18 (CFITSIO V3.400)
1 Header-Data Units in this file.
=================== HDU 1: Primary Array ===================
*** Warning: Some CRVALi keywords appear to be missing; expected 2.
   1 | SIMPLE  =                    T / file does conform to FITS standard
   2 | BITPIX  =                   16 / number of bits per data pixel
   3 | NAXIS   =                    2 / number of data axes
   4 | NAXIS1  =                 3336 / length of data axis 1
   5 | NAXIS2  =                 2496 / length of data axis 2
   6 | BZERO   =                32768 / offset and data range to that of unsigned short
   7 | BSCALE  =                    1 / default scaling factor
   8 | CRPIX1  =                 1668 / reference spectrum pixel coordinate for axis 1
   9 | CRPIX2  =                 1248 / reference spectrum pixel coordinate for axis 2
  10 | CTYPE1  = 'RA---DEF'           / standard system and projection
  11 | CTYPE2  = 'DEC--DEF'           / standard system and projection
  12 | OBJECT  = 'Flats qhy9 tak106 HaLRGB' / Object name
  13 | DATE-LOC= '2017-06-23T16:12:37' / Local observation date
  14 | DATE-OBS= '2017-06-23T14:12:37' / UTC observation date
  15 | IMAGETYP= 'FLAT    '           / Type of frame
  16 | CREATOR = 'Sequence Generator Pro v2.5.1.17' / Capture software
  17 | INSTRUME= 'QHY9 CCD Camera.'   / Instrument name
  18 | FWHEEL  = 'QHYCCD FilterWheel' / Filter Wheel name
  19 | FILTER  = 'Ha      '           / Filter name
  20 | EXPOSURE=                    7 / Exposure time in seconds
  21 | CCD-TEMP=    -24.7876596310417 / Camera cooler temperature
  22 | SET-TEMP=    -24.7876596310417 / Camera cooler temperature
  23 | XBINNING=                    1 / Camera X Bin
  24 | CCDXBIN =                    1 / Camera X Bin
  25 | YBINNING=                    1 / Camera Y Bin
  26 | CCDYBIN =                    1 / Camera Y Bin
  27 | XPIXSZ  =                  5.4 / Pixel Width in microns (with binning)
  28 | YPIXSZ  =                  5.4 / Pixel Height in microns (with binning)
  29 | END
 29 header keywords
 16-bit integer pixels,  2 axes (3336 x 2496),
++++++++++++++++++++++ Error Summary  ++++++++++++++++++++++
 HDU#  Name (version)       Type             Warnings  Errors
 1                          Primary Array    1         0
**** Verification found 1 warning(s) and 0 error(s). ****
This is the outcoming..
Re: FIT files
« Reply #5 on: 2017 August 09 04:38:47 »
Hi Bram,
Then I need the original FITS file that is causing problems. Can you upload it?
