Author Topic: Where is Batch Debayer?  (Read 3067 times)
Offline Raymond
    • Astrophotography
« on: 2017 August 09 02:16:35 »
Actually, I have a problem of how to preprocess the images acquired with my Canon. Until now, my procedure was to use Image Calibration, Cosmetic Correction and Batch Debayer on all of my images. With the latest update, I found only the script Batch CMYG Debayer (applied to fits-files) which doesn't work with my images. How is it possible to debayer a whole set of images?
It is still possible to use the Debayer and Image Container-Process Container detour, but the former Batch Container was more comfortable.
Thanks for your help
Raymond
Raymond
Planewave 14" CDK - 10Micron GM2000HPS
William Optics 110/770 & FF | HEQ5-Pro
Omegon 66/400 | MGEN-Lacerta
Canon 500d mod
Re: Where is Batch Debayer?
« Reply #1 on: 2017 August 09 02:53:56 »
Raymond
The Batch Debayer script has been retired as such. The regular Debayer tool now has batch capabilities like the script but also has the added advantage of being multi-threaded and auto detection for mosaic pattern. I think you'll like the speed increase.
Offline Raymond
    • Astrophotography
« Reply #2 on: 2017 August 09 04:37:36 »
Hi Mike
Thanks for your quick reply. And I should have had a closer look at the Debayer-Tool from the beginning.
All problems solved! Thanks!!
Raymond
Raymond
Canon 500d mod
Offline daimoniro
« Reply #3 on: 2017 August 18 06:17:13 »
I'm doing a standard workflow for OSC image (CANON DLSR).
In your experience when I have to debayer the XISFs?
I ask because in various tutorial the debayer process is after the cosmetic correction and before StarAlignment process.
But applying the live preview of cosmetic correction on a not debayer image I have some problem in order to find hot pixel.
Lorenzo
