Author Topic: Pixinsight 1.8.5 hangs after bugfix  (Read 1022 times)
Offline cbradshaw
    • Charlie's Tree House Observatory
« on: 2017 August 07 17:28:14 »
I opened PI and was notified that the latest math bugfix was available, which I downloaded.  I continued working in PI.  When I closed PI, it asked if I wanted to install the update.  I unchecked restart PI and said yes.  Nothing! I tried to restart PI, but it would not come up.  Opening the task manager, I saw PI running in background and killed the process.  I restarted PI and it indicated the bugfix was ready for download again.  I downloaded it again and closed PI.  This time I said restart PI and everything worked as expected.  Easy work around, but should be fixed.
Charlie
Charlie - G11, CGEM, SV115T20, Meade SN8, Mod Canon 20d and T3, QSI 683 WSG,
Re: Pixinsight 1.8.5 hangs after bugfix
« Reply #1 on: 2017 August 07 20:12:41 »
how long was PI running in the background like that? seconds? or minutes?
sometimes it takes a while for PI to clean up all it's temporary directories, so it might be normal for it to take a bit of time to quit.
« Reply #2 on: 2017 August 08 00:27:36 »
Hi Charlie,
Looks like a bug. I'll investigate. To be honest, I have not tested the update system without relaunching the application for a long time. Thank you for reporting.
