Author Topic: .xisf being changed back to .fit  (Read 2697 times)
Offline Starcruiser
« on: 2017 August 07 13:59:59 »
Just started using v1.8.5 and after loading my .xisf image files into StarAlignment all the files are processed and saved with .fit extenders in the output directory.
What is causing the change?  I do not see any setting in StarAlignment that causes this change.
Re: .xisf being changed back to .fit
« Reply #1 on: 2017 August 08 10:24:48 »
The only way for this to happen is if you have launched a StarAlignment process icon generated with version 1.8.4 (for example, an icon pertaining to a project, or loaded from an xpsm file), where the output extension had been set to ".fit". Reset the StarAlignment tool, then repeat the alignment process, and you should get XISF files.
Offline Starcruiser
« Reply #2 on: 2017 August 09 08:24:08 »
Thanks Juan,
Loaded a fresh instance of PI instead of project and sure enough StarAlignment maintained the .xisf file extensions.
