Author Topic: can't make a mask with latest version of PI  (Read 2514 times)
Offline georgian82
« on: 2017 August 06 22:19:52 »
Hi all,
After extracting lightness to create a mask, it is almost impossible to simply drag it into the frame of the image you want to work on. When I drag it an drop it right on to of the border of the image, it creates a clone of the lightness instead of a mask. This never happened with the previous version of PI.
Is there another way of creating a mask other than the method I described?
Thanks!
Offline Stu
Re: can't make a mask with latest version of PI
« Reply #1 on: 2017 August 06 22:26:19 »
I just tried myself.   It works okay for me.
Stuart
Offline RickS
« Reply #2 on: 2017 August 06 23:18:27 »
Right click on an image: Mask > Select Mask
What platform are you running on?  Seems like the new version of Qt is causing some problems, especially on OSX.
« Reply #3 on: 2017 August 07 04:36:22 »
Please see this post for more information:
https://pixinsight.com/forum/index.php?topic=11292.0
You definitely *can* define masks by dragging view selectors on macOS. Just be patient and get accustomed to the new, somewhat less accurate drag'n drop behavior of the application on macOS. As noted on the post above, this problem is being caused by a serious regression in the macOS version of the main support library used to build PixInsight. I am working on a solution, but this problem is very difficult to solve. I am sorry about this.
Offline Stu
« Reply #4 on: 2017 August 07 09:27:35 »
I apologize for my prior post.  I didn't realize the OP was working on Mac.  I have a Windows machine.
Offline georgian82
« Reply #5 on: 2017 August 07 21:38:01 »
Thank you! That is exactly what I was looking for. I am running PI on OSX.
Offline georgian82
« Reply #6 on: 2017 August 07 21:39:27 »
Thank you Juan for the reply...I appreciate it and I know that you guys are doing what  you can to solve this problem.
Saludos,
