Author Topic: The Eastern Veil processed with 1.8.5  (Read 1817 times)
Offline RickS
« on: 2017 August 04 03:54:55 »
The Eastern Veil in narrowband with a little RGB in the stars.
Captured at SRO, June-July, 2017
Objects in image:
  NGC6992, NGC6995, IC1340
Scope: Ceravolo C300 @ f/4.9 = 1470mm FL
Mount: AP1100
Camera: FLI PL16803
Focuser: Atlas
Filters: Astrodon
Guiding: Lodestar II / Tak guide scope
Image scale: 1.26 arcsec/pixel (Drizzled to double res)
Exposures: 48x300s R, 52x300s G, 37x300s B, 27x1800s Ha, 31x1800s Oiii, 32x1800s Sii (56.4 hours)
Processing: PixInsight 1.8.5
Acquisition credit: Scott Johnson, Augusto Hernandez, John Kasianowicz, Daniele Malleo, Jose Mtanous and Rick Stevenson
Processing credit: Rick Stevenson
Offline edif300
    • http://www.astrosurf.com/ilizaso
Re: The Eastern Veil processed with 1.8.5
« Reply #1 on: 2017 August 10 02:57:12 »
Beautiful image!!
CS
I.
Astroargazkigintza
Offline RickS
« Reply #2 on: 2017 August 10 03:53:44 »
Thanks again, IƱaki  :D
Offline Ryderscope
« Reply #3 on: 2017 August 14 23:30:58 »
Hi Rick, when you say that you have added some RGB into the stars - is this achieved by processing the RGB data seperately and then adding this into the narrow band data using pixel math and a star mask overlay?
Offline RickS
« Reply #4 on: 2017 August 14 23:56:14 »
Hi Rodney,
I processed the RGB data without too much care apart from the star colours.  Then I extracted the L*, a* and b* from the NB image and the a* and b* from the RGB.  I applied a star mask to the NB a* and b* and used PixelMath to blend the a* and b* from the RGB channels into the corresponding NB channels.  Then I recombined the L* and blended a* and b* to make the final image.  Effectively, I blended the colour from the RGB image into the NB image through a star mask while retaining the original Lightness (and star profiles).  Hope that makes sense. It's probably easier to do than explain :)
Rick.
« Reply #5 on: 2017 August 15 08:40:54 »
And Rick just to be clear as I did not see this in your post I would think you made the star mask from the NB data and not the RGB in order to keep the NB star profiles.
Offline RickS
« Reply #6 on: 2017 August 15 13:32:15 »
That's correct, thanks Mike.
Offline Ryderscope
« Reply #7 on: 2017 August 17 05:17:33 »
Thanks Rick and Mike for clarifying that for me. Will step through this approach when next I venture into NB.
