Author Topic: weird pattern from bias integration  (Read 2045 times)
Offline cosmochristo
« on: 2017 August 03 03:27:29 »
Hi, I am new to pixinsight and have found integrating bias frames gives a strange pattern (see attached). Frames taken using a canon 5D III, 8-15mm fisheye lens at 11mm. They have been converted to tiff images using Canon's DPP. iso 50, 1/8000s.
Re: weird pattern from bias integration
« Reply #1 on: 2017 August 03 04:47:06 »
I think I know: All images I converted to tiff using the same operations as on the light frames and that included the distortion correction operator. Looks like the one thing I should not have done!
Offline Greg Schwimer
« Reply #2 on: 2017 August 04 01:29:27 »
Well....
With bias frames, what lens you have on there should not matter. In fact, the shutter should be closed. You could conceivably grab bias (and dark) frames with the camera completely detached from the optics.
What software, exactly, is correcting optical distortion on a bias frame that should never see light from any source?
Maybe don't use whatever is doing that and stick with PI for the very early preprocessing of the data.
My $2e-02.
- Greg
Scottsdale, Arizona, USA
