Author Topic: Stitching images together  (Read 2856 times)
Offline dpaul
« on: 2017 August 01 16:58:03 »
Can anyone help with the following question -
I've got a 30'' F3.5 scope which is great for getting fine detail on individual smaller deep sky object such as M81 but would only capture a fraction of M45.
I'm aware from the past that there were ways to stitch images together to get panoramic shots. Is there an process with PI that allows stitching a mosaic of smaller fields of view to get a big one?
Regards
David
Re: Stitching images together
« Reply #1 on: 2017 August 01 18:43:22 »
yes - several.
i'd say the state of the art would be to solve each pane with ImageSolver, then run MosaicByCoordinates on the solved images, then use GradientsMergeMosaic to merge together the output of MosaicByCoordinates.
that image was produced with the above method.
Offline dpaul
« Reply #2 on: 2017 August 02 01:39:20 »
Hi Rob,
Wow, that's a big image!
I managed to find the first two steps unders 'scripts' and the last one under' processes' so at least I know how to start - thanks.
Just one question, could you give a high level comment on each script just to say fundamentally the purpose of each?
David
Offline Andres.Pozo
« Reply #3 on: 2017 August 02 02:32:33 »
Both scripts have documentation. You can read it clicking the documentation button in the window of each script, or online at:
https://pixinsight.com/doc/scripts/ImageSolver/ImageSolver.html
https://pixinsight.com/doc/scripts/MosaicByCoordinates/MosaicByCoordinates.html
Andrés
Offline dpaul
« Reply #4 on: 2017 August 02 17:11:02 »
Thanks Andrés
Regards
David
Offline Robert Q. Kimball
« Reply #5 on: 2017 August 04 13:13:17 »
I'd suggest you watch this video on YouTube
https://youtu.be/H2r3ZYqCaP8
Offline dpaul
« Reply #6 on: 2017 August 04 13:42:35 »
Thanks Rob
David
