When the Shadows, Midtones, and Highlight readout button is pressed and the cursor is clicked on the active/tracked view- the associated fields do not populate with the value.
This functionality works with the STF utility... but as far as I can tell, does not in HT. The vertical lines do correctly display the readout value.
I am currently at 01.08.04.1170.
UPDATE: I can be more specific now... when I click on the image the readout mode sends zero ("0") to the field. At first this was not obvious to me since shadows is already zero. It will zero the midtone field (from 0.5) and highlights (from 1). Does anyone else see this behavior?
-adam
