Author Topic: Invalid Subframe Selector Keyword  (Read 2402 times)
Offline SeattleStarGazer
« on: 2017 July 20 14:10:59 »
Using SFS for the first time. Entered a weighting expression that I got from a spreadsheet that worked and I entered SFSWEIGHT for the keyword and output the frames. I then registered the frames and tried image integration and got this error message
Error: D:/Astro/Pelican/Registered/Pelican--%2017-07-14--1x1--frame2_c_cc_a_r.xisf: Nonexistent or invalid weight keyword 'SFSWEIGHT'.
<* failed *>
This was the expression
18*((1/(FWHM^2))-0.124861092035111)/0.158072362016496 + 6*(1-(Eccentricity-0.374)/0.411) + 36*(SNRWeight-0.755)/0.081 + 40
I did check the FITS headers and the keyword was there and spelled correctly. Any ideas?
Offline RickS
Re: Invalid Subframe Selector Keyword
« Reply #1 on: 2017 July 20 18:29:55 »
The only times I have had an error like this it has been user error (I ran registration on files in the wrong directory, had an old file lying around, etc.)
Rick.
Offline mschuster
« Reply #2 on: 2017 July 20 20:16:12 »
Double check that all weights are positive. Zero and negative weights will cause this error.
Also you might want to use a keyword with at most 8 letters. I think this is an official FITS requirement. PI may be able support more, so this might not be the problem.
Offline RickS
« Reply #3 on: 2017 July 20 20:35:50 »
I have used the keyword "SFSWEIGHT" successfully, Mike, but checking for a zero or negative value is a good suggestion.
