Looking at your processing examples you produce a star mask to protect the larger to medium stars, but I don't see how you use that mask in the deconvolution process. I thought it was used in the local deringing section, but your screenshots do not show it used there. So I am a little confused.
Hi Mike, In general I have managed to solve the deringing problems with "Global dark" and "Global bright" settings, but Local support may help if necessary.
On most tutorials, they use a L mask to protect the background and only apply the deconvolution where there's data (the bright part usually).
ChoJin, if you use a Regularizated Algorithm like Richardson-Lucy which is the default it enables "Wavelet Regularization" at the bottom of Deconvolution tool. Adjusting those setting allows you to control the effect of deconvolution on the background of your images. In most of the cases this is enough in medium and high SNR image.
If I understand correctly, what you're saying is that I should generate a starmask for the big stars (especially the ones with spikes) and subtract those from the L mask before applying it (hence excluding the big stars from the deconvolution as well)?
No, I suggest only to mask the big stars. Check
this mask article in the "StarMask with StarMask tool" section where I have created an star mask to protect only big stars before applying deconvolution.
Saludos, Alejandro.
