Author Topic: Repository error  (Read 2632 times)
Offline gmcfall
Repository error
« on: 2017 June 15 12:10:12 »
I'm currently running Pixinsight -1.08.04- on two different Windows 7 computers. The same pixinsight-license file is on both machines. They both work fine, however the desktop shows a failed to load repository error briefly at startup. The laptop does not. Because of the error I can't install updates. This probably is a computer issue, any suggestions ?
Thanks.
Gary
Offline John_Gill
Re: Repository error
« Reply #1 on: 2017 June 17 04:25:16 »
Does the PC that has the repository error have an internet connection?
Look up
John
APM 107/700 apo on CGX mount
ZWO Optics - Autoguiding
ZWO1600mm and filters
Offline gmcfall
« Reply #2 on: 2017 June 17 12:46:36 »
John,
Yes it does. I tried reloading the Pixinsight License file, but that didn't work. A friend said he had the same problem and Pixinsight told him to edit a line in a text file, butr he cant remember which one.
Gary
« Reply #3 on: 2017 June 17 19:49:43 »
Hi Gary, this video may help. Saludos, Alejandro.
Offline oldwexi
    • Astronomy Pages G.W.
« Reply #4 on: 2017 June 18 02:22:28 »
Gary, you can check which update repositories you have selected on each machine with clicking in the upper tab row
RESOURCES
         Updates
               Manage Repositories
This gets you the info what respositories you have selected on the specific PC.
I assume on the new installtion you will have less repositories defiined?
Gerald
Offline gmcfall
« Reply #5 on: 2017 June 18 12:30:04 »
Thanks everybody. T tried the suggestions, but the same thing. I ended up pixinsight uninstalling the whole program and reinstaling it. I still get the error, but It installed all the latest updates for me. I guess that's the workaround.
Thanks again for all the inputs.
Gary
