What is the problem here?
Typical FITS interoperability issue. The bias frames, despite the fact you have selected an unsigned 16-bit integer range, have been stored as signed 16-bit images where only the positive half of the numeric range is being used (and hence they are actually 15-bit images).
Open the Format Explorer window, double click the FITS item on the left panel, and make sure the
signed integer images store physical pixel data option is checked, then click OK. This option is always enabled by default, so this problem should not happen. Which version of PixInsight are you running?
