Author Topic: Is there a script to match darks, lights, flats for common iso, exposure, temp  (Read 2027 times)
Offline bjaffa
Is there a way in PixInsight to match masters & images for common iso, exposure, & temperature of
files you want to import to BatchPreProcessing script?
I know of a "Dark Master" utility which generates a DSS list that can be used for DSS.
I am wondering if there is a way to have Pixinsight parse my master files (ie darks, bias) and select
the appropriate master files (based on a Temperature range, iso setting, & exposure) for use with a set of lights
based on the EXIF data contained in the Lights?
Basically for use by DSLR's where temperature is not strictly controlled.
Thanks for any suggestions.
Brent
« Last Edit: 2017 May 23 11:25:41 by bjaffa »
