Hi there, I've been a user of PI since a while already and appreciate all the help coming from this forum, even if I never posted a question directly, thank you all!
Ok, here's the problem:
since I changed my setup adding a Barlow lens, the flats became uglier and now PI doesn't seem to be able to correct the subs properly.
I haven't been taking pictures for 8 months or so, meanwhile PI has been updated and so I'm not sure the issue is only cause by the quality of the subs or if I'm missing some new "knobs" in PI compared to the past.
I've also noticed warnings all the time now regarding Darks, these were not appearing last year and I haven't investigated yet why that is the case.
Now to the pictures!
First you can see how the old flats looked like, there is a main reflection which is repeated a few times.
Now the new flats have the same issue but with smaller size (probably due to the added Barlow) but spread all over the shop, plus one uglier area which wasn't present before.
Even with 20 flats PI doesn't seem to be able to correct the subs, third picture is a session from last night, stack of 25 light of 3 minutes each plus, 20 flats, 10 darks (taken from a master) and 20 bias (also taken from a master).
where I see the "wavy" pattern that can be taken care of only by moving the black point very high and eating a lot of information (which I wouldn't want to do), I've exaggerated the stretching to highlight the problem.
I'm planning to go to the basics and start taking subs and flats simplifying the image train, but if you have any suggestion how to process the current subs or where to look specifically that will be more than welcome!
My imaging setup is a Skywatcher 750/150 PDS newtonian, the 2.5x 2" barlow lens, an Atik Filter wheel with Baader RGB/NB filter and an Atik 414 EX.
PS I tried to stretch the images to highlight the problems
PPS I'm tempted to get rid of the Barlow and move to an 8" RC telescope to get the a bit more light and same focal length, but before making the purchase I'd like to understand if I'm asking too much of the good old newtonian!
