Author Topic: Dark subtract problem  (Read 2405 times)
Offline Astrobobo
« on: 2017 April 28 04:22:09 »
Hello all,
I'm new to the forum, but I've been into astrophotography on and off for quite a while. Still, I have silly problem I can't find the answer to - my master dark won't get rid of all the bright columns on the CCD. I'm using a STL-11000. I tired cosmetic correction, but it doesn't work, I'm left with those really prominent bright columns.
If someone would like to have a go, I'd really appreciate it. I've included the master dark and one L light on this link: https://drive.google.com/open?id=0B42bW-rSyIhrUEJLQzlCZDdBd2M
Thanks and greetings from Croatia! :)
Offline chris.bailey
Re: Dark subtract problem
« Reply #1 on: 2017 April 28 09:45:43 »
Try Cosmetic Corrections Use Defect List section and add columns 426, 527, 3428, 3596 and 3614. That gets rid of any residual from dark subtraction.
Chris
Offline Astrobobo
« Reply #2 on: 2017 May 01 01:07:42 »
Thanks, sorry for the late reply. It actually works!
I'm still at a loss why the dark frame didn't get rid of those in the first place.
« Last Edit: 2017 May 01 01:27:23 by Astrobobo »
« Reply #3 on: 2017 May 01 05:56:43 »
One of my CCD's has similar defects and darks don't fully correct them either. I "think" it has to do with the pixel values in the defects varying quite a bit from frame to frame. With a master dark those values are averaged so when subtracted there are slight residual variances.
Glad CC worked for you. Adding a large dither on capture can help too.
Chris
Offline Astrobobo
« Reply #4 on: 2017 May 03 21:39:26 »
I'm not so sure...those columns are really bad.
