Author Topic: Reference Image question  (Read 2286 times)
Offline dnewbury
« on: 2017 April 03 04:23:21 »
I have 3 narrowband stacked images - which I stacked some time ago but have not got around to combining until now. It looks like 1 of the images is not aligning to the other two. I *thought* I had used the same reference frame for all 3 when stacking - but guess not   :-\
Is there a way to identify which reference frame was used for each stack? What options do I have short of re-stacking everything from scratch?
DaveNL
Offline aworonow
    • Faint Light Photography
Re: Reference Image question
« Reply #1 on: 2017 April 03 06:57:35 »
You could re-register 2 of the stacks to the third very quickly.
Alternatively, if the 3 stacks are part of a project, the history of those frames probably has what reference frame(s) were used.
Alex
Offline dnewbury
« Reply #2 on: 2017 April 03 11:32:51 »
Alex,
Thanks for the input.
Unfortunately, the project file I have does not go back to the time when images were registered/integrated.  :(
If I don't know which image was reference frame for the "3rd" stack. How would I be able to re-register the other two, to match? I think I am missing something?
DaveNL
Offline RickS
« Reply #3 on: 2017 April 03 14:30:19 »
If you have the original data then I'd just go back and register/stack it all again, but if you don't want to do that you can do what Alex suggested (though I'd recommend you only re-register the one master that doesn't match the other two - the interpolation will damage the data slightly, so it makes sense to only do it to one master rather than two.)
Use StarAlignment with one of the "good" masters as a reference and apply it to the "bad" one.
Rick.
