PI 1.5.2 now allows to get the STF active in a view. I have modified the 3dplot script to apply the same STF active in the view instead asking the user for a MTF value. This also solves the problem of finding a good value for the "floor" of the plot.
The configuration dialog is now a bit simpler but I also think the plot is more controllable using the STF window. A couple of examples:
This is the new code:
// PixInsight JavaScript Runtime API - PJSR Version 1.0
// Copyright (C) 2003-2009 Pleiades Astrophoto. All Rights Reserved.
// pjsr/3DPlot.js - Released 2009/06/05 15:52:25 UTC
// This file is part of the PJSR. The PJSR is a JavaScript API for development
// of scripts on the PixInsight platform (ECMAScript 262-3 compliant).
// The PJSR is provided in the hope that it will be useful, but it is
// distributed "AS IS" WITHOUT ANY WARRANTY; without even the warranties of
// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
3DPlot v1.2
A script to generate three-dimensional image renditions.
Copyright (C) 2009 Andrés del Pozo, David Serrano, Juan Conejero
This program is free software: you can redistribute it and/or modify it
under the terms of the GNU General Public License as published by the
Free Software Foundation, version 3 of the License.
This program is distributed in the hope that it will be useful, but WITHOUT
ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for
more details.
You should have received a copy of the GNU General Public License along with
this program. If not, see <http://www.gnu.org/licenses/>.
Changelog:
1.2: Uses the STF active in the view instead asking the user for a MTF value
1.1: Added SVG output. This is mainly intended to test the new SVG
generation capabilities available in PI 1.5.
Fixed generation of image renditions with transparency. When
necessary, an alpha chanel is now generated automatically.
1.0: Several improvements to the user interface and a few optimizations.
Replaced CreatePerspective() by a _3dplot_xform object.
Some identifiers changed for coherency.
0.9: License, changelog, bare-bones user interface.
0.8: Smooth color transitions.
0.7: Reimplemented the possibility of rotating the 3D view.
0.6: Visualization now maps the height to a color palette.
0.5: The script can now be aborted by the user.
The script shows progress information on the console.
The perspective transformation points are now calculated faster.
The MTF transformation is now carried out using a HT.
0.4: Optional shading effect added.
0.3: The resulting image shows the full extent of the 3D view.
The code has been reorganized and structured.
A MTF is applied to the image to improve the visualization.
The perspective transformation has been simplified again.
There is a couple of checks before starting the algorithm.
0.2: It now works on grayscale images.
The 3D image is centered in the output image.
The code is a bit simpler.
It is now 7 times faster.
0.1: Initial test version.
#define TITLE "3DPlot"
#define VERSION "1.2"
#include <pjsr/ColorSpace.jsh>
#include <pjsr/FillRule.jsh>
#include <pjsr/FrameStyle.jsh>
#include <pjsr/NumericControl.jsh>
#include <pjsr/UndoFlag.jsh>
#feature-id Utilities > 3DPlot
#feature-info A script to generate three-dimensional image renditions. \
Optional output as a new image or as a SVG file.<br/> \
<br/> \
Copyright © 2009 Andrés Pozo, David Serrano (PTeam), \
Juan Conejero (PTeam)
//#feature-icon 3dplot.xpm
// Creates the parameters object.
function _3dplot_params()
this.srcView = ImageWindow.activeWindow.currentView;
this.svgOutput = false;
this.svgFileName = File.systemTempDirectory + "/3dplot.svg";
this.azimuth = 30; // Perspective angle in degrees
this.elevation = 20; // Perspective elevation angle
this.scaleXY = 6; // Scale factor for X and Y axis
this.scaleZ = 50; // Scale factor for Z axis
this.backgroundColor = 0xff403000;
this.polygonFill = 0xffffffff;
this.polygonBorder = 0x80000000;
this.useShading = true; // Apply shading effect
this.lightBrightness = 2000; // Light intensity for the shading effect
this.paletteElems = 256;
this.palette = [ [0x80,0,0] , [0,0x80,0] , [0,0,0xC0], [0x80,0,0x80], [0x80,0x80,0], [0,0x80,0x80], [0x80,0x80,0x80] ];
var perspecParams = new _3dplot_params;
// Applies the perspective transformation to all the pixels in the image
function _3dplot_xform(src, perspecParams)
// Calculates the coordinates of each pixel applying the perspective transformation
this.points=new Array;
this.limits=new Rect( 1e10, 1e10, -1e10, -1e10 );
// Projection matrix
var alpha=Math.rad(90-perspecParams.elevation);
var beta=Math.rad(perspecParams.azimuth);
var m00=Math.cos(beta);
var m10=-Math.sin(beta);
var m20=0;
var m01=Math.cos(alpha)*Math.sin(beta);
var m11=Math.cos(alpha)*Math.cos(beta);
var m21=-Math.sin(alpha)*perspecParams.scaleZ;
src.initializeStatus( "Computing 3D coordinates", src.height );
for (var y = 0; y < src.height; y++) {
this.points[y]=new Array;
var m10y = m10*y;
var m11y = m11*y;
for (var x = 0; x < src.width; x++){
var z = src.sample(x,y);
var p = new Point( m00*x + m10y, m01*x + m11y + m21*z );
p.mul( perspecParams.scaleXY );
this.points[y][x] = p;
if (p.x < this.limits.left) this.limits.left = p.x;
if (p.x > this.limits.right) this.limits.right = p.x;
if (p.y < this.limits.top) this.limits.top = p.y;
if (p.y > this.limits.bottom) this.limits.bottom = p.y;
src.advanceStatus( 1 );
gc();
function ApplySTF(src, stf)
console.writeln(stf[0]);
console.writeln(stf[1]);
console.writeln(stf[2]);
console.writeln(stf[3]);
var low=(stf[0][1]+stf[1][1]+stf[2][1])/3;
var mtf=(stf[0][0]+stf[1][0]+stf[2][0])/3;
var hgh=(stf[0][2]+stf[1][2]+stf[2][2])/3;
// Faster solution using a process instance
var HT = new HistogramTransformation;
HT.H =
[[ 0, 0.5, 1, 0, 1],
[ 0, 0.5, 1, 0, 1],
[ 0, 0.5, 1, 0, 1],
[low, mtf, hgh, 0, 1],
[ 0, 0.5, 1, 0, 1]];
var wtmp = new ImageWindow( 1, 1, 1, 16, false, src.colorSpace != ColorSpace_Gray );
var v = wtmp.mainView;
v.beginProcess( UndoFlag_NoSwapFile );
v.image.assign( src );
v.endProcess();
HT.executeOn( v, false ); // no swap file
src.assign( v.image );
wtmp.close();
function DieError(message)
var msgb=new MessageBox(message,"Error generating 3D view");
msgb.execute();
throw Error( message );
function ApplyLighting(basecolor, light)
var r=(basecolor[0]*light/1000);
r=r>255?255:r;
var g=(basecolor[1]*light/1000);
g=g>255?255:g;
var b=(basecolor[2]*light/1000);
b=b>255?255:b;
return 0xFF000000 | (r<<16)| (g<<8) | b;
// the resulting palette doesn't have to be exactly 'num' elements long.
function ExpandPalette(params)
var p = params.palette;
var num = params.paletteElems;
var expanded = new Array;
var steps = Math.round (num / p.length); // steps between two provided palette elements
for (var c = 0; c < p.length - 1; c++) {
var from = p[c];
var to = p[c+1];
var step_red = (to[0] - from[0]) / steps;
var step_green = (to[1] - from[1]) / steps;
var step_blue = (to[2] - from[2]) / steps;
for (var s = 0; s < steps; s++) {
var new_red = from[0] + s * step_red;
var new_green = from[1] + s * step_green;
var new_blue = from[2] + s * step_blue;
expanded.push ([ new_red, new_green, new_blue ]);
// add last user-supplied palette element
expanded.push (p[p.length-1]);
params.palette = expanded;
function Render( src, g, limits, xform, perspecParams)
g.antialiasing=true;
// Applies a translation to the graphics to center the image
g.translateTransformation(-limits.left,-limits.top);
ExpandPalette (perspecParams);
var fillbrush=[];
if(!perspecParams.useShading){
for(var c=0;c<perspecParams.palette.length;c++)
fillbrush[c]=new Brush(0xFF000000 | (perspecParams.palette[c][0]<<16) | (perspecParams.palette[c][1]<<8) | perspecParams.palette[c][2]);
g.pen = new Pen (perspecParams.polygonBorder,0);
} else
// Using shading the polygon borders should be less visible
g.pen = new Pen ((perspecParams.polygonBorder&0x00FFFFFF) | 0x20000000);
src.initializeStatus( "Rendering 3D profile", src.height-1 );
// Paint the polygons from back to front
for (var n = 0; n < src.height-1; n++) {
for (var m = 0; m < src.width-1; m++) {
var z1=src.sample(m,n),
z2=src.sample(m+1,n),
z3=src.sample(m,n+1),
z4=src.sample(m+1,n+1);
// Get the palette index
//var z=(z1+z2+z3+z4)/4;
var zM=Math.max(Math.max(z1,z2),Math.max(z3,z4));
var zm=Math.min(Math.min(z1,z2),Math.min(z3,z4));
var z=(zm+zM)/2;
var palidx=Math.round(z*perspecParams.palette.length);
palidx=palidx<0 ? 0 : (palidx>=perspecParams.palette.length ? perspecParams.palette.length-1 : palidx);
if(perspecParams.useShading){
// Get the lighting factor
var slope=z1-z2+z3-z4;
var lighting=(slope+0.5)*perspecParams.lightBrightness;
lighting=lighting<0 ? 0 : Math.round(lighting);
g.brush=new Brush(ApplyLighting(perspecParams.palette[palidx], lighting));
} else
g.brush=fillbrush[palidx];
var polygon=new Array(
xform[n][m],
xform[n][m+1],
xform[n+1][m+1],
xform[n+1][m]);
g.drawPolygon (polygon);
function RenderImage( src, img, limits, xform, perspecParams)
var bmp = new Bitmap( img.width, img.height );
bmp.fill( perspecParams.backgroundColor );
var g = new Graphics( bmp );
Render( src, g, limits, xform, perspecParams);
g.end();
img.blend( bmp );
function RenderSVG( src, svg, limits, xform, perspecParams )
var g = new Graphics( svg );
g.fillRect( svg.size, new Brush( perspecParams.backgroundColor ) );
Render( src, g, limits, xform, perspecParams );
g.end();
function _3dplot_dialog() {
this.__base__ = Dialog;
this.__base__();
var labelWidth1 = this.font.width( "Polygon border color:" );
var editWidth1 = 9*this.font.width( "0" );
var editWidth2 = 12*this.font.width( "0" );
// help label
this.helpLabel = new Label (this);
with (this.helpLabel) {
frameStyle = FrameStyle_Box;
margin = 4;
wordWrapping = true;
useRichText = true;
text = "<p><b>" + TITLE + " v" + VERSION + "</b> — A " +
"script to generate 3D image renditions.</p>" +
"<p>Copyright © 2009 Andrés Pozo / David Serrano / Juan Conejero</p>";
// source image
this.srcImage_Label = new Label( this );
this.srcImage_Label.minWidth = labelWidth1;
this.srcImage_Label.text = "Source image:";
this.srcImage_Label.textAlignment = TextAlign_Right|TextAlign_VertCenter;
this.srcImage_ViewList = new ViewList( this );
this.srcImage_ViewList.minWidth = 250;
this.srcImage_ViewList.getAll(); // include main views as well as previews
this.srcImage_ViewList.currentView = perspecParams.srcView;
this.srcImage_ViewList.toolTip = "<p>Select the image to be rendered.</p>";
this.srcImage_ViewList.onViewSelected = function( view )
perspecParams.srcView = view;
this.srcImage_Sizer = new HorizontalSizer;
this.srcImage_Sizer.spacing = 4;
this.srcImage_Sizer.add( this.srcImage_Label );
this.srcImage_Sizer.add( this.srcImage_ViewList, 100 );
// SVG Output
this.svgOutput_CB = new CheckBox (this);
with (this.svgOutput_CB) {
text = "SVG Format";
checked = perspecParams.svgOutput;
onCheck = function (checked) {
perspecParams.svgOutput = checked;
this.dialog.svgFileName_Label.enabled = checked;
this.dialog.svgFileName_Edit.enabled = checked;
this.dialog.svgFileName_Button.enabled = checked;
toolTip = "<p>Select this option to generate the 3D rendition in Scalable Vector Graphics " +
"format (SVG). Otherwise the rendition will be generated as a new image window.</p>" +
"<p><b>* Warning *</b> SVG files can be very large even for relatively small images.</p>";
this.svgOutput_Sizer = new HorizontalSizer;
this.svgOutput_Sizer.addSpacing( labelWidth1+4 );
this.svgOutput_Sizer.add( this.svgOutput_CB );
this.svgOutput_Sizer.addStretch();
// SVG Filename
this.svgFileName_Label = new Label( this );
with ( this.svgFileName_Label ) {
text = "SVG output file:";
enabled = perspecParams.svgOutput;
this.svgFileName_Edit = new Edit( this );
with ( this.svgFileName_Edit ) {
text = perspecParams.svgFileName;
onEditCompleted = function() { perspecParams.svgFileName = this.text; };
this.svgFileName_Button = new ToolButton( this );
with ( this.svgFileName_Button ) {
icon = new Bitmap( ":/images/icons/select.png" );
toolTip = "<p>Select a SVG output file.</p>";
onClick = function() {
var gdd = new SaveFileDialog;
gdd.initialPath = perspecParams.svgFileName;
gdd.caption = "Select SVG Output File";
gdd.overwritePrompt = true;
gdd.filters = [["SVG Files", "*.svg"]];
if ( gdd.execute() )
perspecParams.svgFileName = gdd.fileName;
this.dialog.svgFileName_Edit.text = perspecParams.svgFileName;
this.svgFileName_Sizer = new HorizontalSizer;
with ( this.svgFileName_Sizer ) {
spacing = 4;
add( this.svgFileName_Label );
add( this.svgFileName_Edit, 100 );
add( this.svgFileName_Button );
// azimuth
this.azimuth_NC = new NumericControl (this);
with (this.azimuth_NC) {
real = false;
label.text = "Azimuth:";
label.minWidth = labelWidth1;
setRange (0, 90);
slider.setRange (0, 90);
slider.minWidth = 250;
edit.minWidth = editWidth1;;
setValue (perspecParams.azimuth);
toolTip = "<p>Azimuth angle in degrees.</p>";
onValueUpdated = function (value) {
perspecParams.azimuth = value;
// elevation
this.elevation_NC = new NumericControl (this);
with (this.elevation_NC) {
real = false;
label.text = "Elevation:";
setRange (0, 90);
setValue (perspecParams.elevation);
toolTip = "<p>Observer's elevation angle above the ground, in degrees.</p>";
perspecParams.elevation = value;
// scaleXY
this.scaleXY_NC = new NumericControl (this);
with (this.scaleXY_NC) {
real = false;
label.text = "X-Y plane scale:";
setRange (1, 10);
slider.setRange (1, 10);
setValue (perspecParams.scaleXY);
toolTip = "<p>Scale of X and Y coordinates in rendition pixels per image pixels.</p>";
perspecParams.scaleXY = value;
// scaleZ
this.scaleZ_NC = new NumericControl (this);
with (this.scaleZ_NC) {
real = false;
label.text = "Z-axis scale:";
setRange (1, 100);
slider.setRange (1, 100);
setValue (perspecParams.scaleZ);
toolTip = "<p>Scaling factor of Z-axis coordinates.</p>";
perspecParams.scaleZ = value;
// mtf
/*this.mtf_NC = new NumericControl (this);
with (this.mtf_NC) {
label.text = "Midtones balance:";
setRange (0, 1);
slider.setRange (1, 500);
setPrecision (3);
setValue (perspecParams.mtf);
toolTip = "<p>This parameter is part of a histogram transformation applied to " +
"improve faint detail visualization.</p>";
perspecParams.mtf = value;
// lightBrightness
this.brightness_NC = new NumericControl (this);
with (this.brightness_NC) {
real = false;
label.text = "Brightness:";
setRange (100, 5000);
slider.setRange (1, 50);
setValue (perspecParams.lightBrightness);
toolTip = "<p>Intensity of incident light.</p>";
perspecParams.lightBrightness = value;
// useShading
this.shading_CB = new CheckBox (this);
with (this.shading_CB) {
text = "Use shading";
checked = perspecParams.useShading;
onCheck = function (checked) { perspecParams.useShading = checked; }
toolTip = "<p>If this option is selected, a special shading algorithm will be used " +
"to enhance the 3-D rendition.</p>";
this.shading_Sizer = new HorizontalSizer;
this.shading_Sizer.addSpacing( labelWidth1+4 );
this.shading_Sizer.add( this.shading_CB );
this.shading_Sizer.addStretch();
// background color
this.backgroundColor_Label = new Label( this );
this.backgroundColor_Label.text = "Background color:";
this.backgroundColor_Label.textAlignment = TextAlign_Right|TextAlign_VertCenter;
this.backgroundColor_Label.minWidth = labelWidth1;
this.backgroundColor_Edit = new Edit( this );
this.backgroundColor_Edit.text = format( "%X", perspecParams.backgroundColor );
this.backgroundColor_Edit.setFixedWidth( editWidth2 );
this.backgroundColor_Edit.toolTip = "<p>Background color encoded as a 32-bit hexadecimal integer.<br/>" +
"(AARRGGBB format: AA=alpha (transparency), RR=red, GG=green, BB=blue)</p>";
this.backgroundColor_Edit.onEditCompleted = function()
perspecParams.backgroundColor = parseInt( this.text, 16 );
this.text = format( '%X', perspecParams.backgroundColor );
this.backgroundColor_Sizer = new HorizontalSizer;
this.backgroundColor_Sizer.spacing = 4;
this.backgroundColor_Sizer.add( this.backgroundColor_Label );
this.backgroundColor_Sizer.add( this.backgroundColor_Edit );
this.backgroundColor_Sizer.addStretch();
// polygon fill color
this.polygonFill_Label = new Label( this );
this.polygonFill_Label.text = "Polygon fill color:";
this.polygonFill_Label.textAlignment = TextAlign_Right|TextAlign_VertCenter;
this.polygonFill_Label.minWidth = labelWidth1;
this.polygonFill_Edit = new Edit( this );
this.polygonFill_Edit.text = format( "%X", perspecParams.polygonFill );
this.polygonFill_Edit.setFixedWidth( editWidth2 );
this.polygonFill_Edit.toolTip = "<p>Polygon fill color encoded as a 32-bit hexadecimal integer.<br/>" +
this.polygonFill_Edit.onEditCompleted = function()
perspecParams.polygonFill = parseInt( this.text, 16 );
this.text = format( '%X', perspecParams.polygonFill );
this.polygonFill_Sizer = new HorizontalSizer;
this.polygonFill_Sizer.spacing = 4;
this.polygonFill_Sizer.add( this.polygonFill_Label );
this.polygonFill_Sizer.add( this.polygonFill_Edit );
this.polygonFill_Sizer.addStretch();
// polygon border color
this.polygonBorder_Label = new Label( this );
this.polygonBorder_Label.text = "Polygon border color:";
this.polygonBorder_Label.textAlignment = TextAlign_Right|TextAlign_VertCenter;
this.polygonBorder_Label.minWidth = labelWidth1;
this.polygonBorder_Edit = new Edit( this );
this.polygonBorder_Edit.text = format( "%X", perspecParams.polygonBorder );
this.polygonBorder_Edit.setFixedWidth( editWidth2 );
this.polygonBorder_Edit.toolTip = "<p>Polygon border color encoded as a 32-bit hexadecimal integer.<br/>" +
this.polygonBorder_Edit.onEditCompleted = function()
perspecParams.polygonBorder = parseInt( this.text, 16 );
this.text = format( '%X', perspecParams.polygonBorder );
this.polygonBorder_Sizer = new HorizontalSizer;
this.polygonBorder_Sizer.spacing = 4;
this.polygonBorder_Sizer.add( this.polygonBorder_Label );
this.polygonBorder_Sizer.add( this.polygonBorder_Edit );
this.polygonBorder_Sizer.addStretch();
// ### TODO: Better color selection controls - Include a ColorSelectionDialog object in PJSR?
// ### TODO: Allow selecting palettes
// buttons
this.ok_Button = new PushButton (this);
this.ok_Button.text = "OK";
this.ok_Button.onClick = function() { this.dialog.ok(); };
this.cancel_Button = new PushButton (this);
this.cancel_Button.text = "Cancel";
this.cancel_Button.onClick = function() { this.dialog.cancel(); };
this.buttons_Sizer = new HorizontalSizer;
this.buttons_Sizer.spacing = 8;
this.buttons_Sizer.addStretch();
this.buttons_Sizer.add (this.ok_Button);
this.buttons_Sizer.add (this.cancel_Button);
// pack everything
this.sizer = new VerticalSizer;
with (this.sizer) {
margin = 8;
spacing = 6;
add (this.helpLabel);
addSpacing (4);
add (this.srcImage_Sizer);
add (this.svgOutput_Sizer);
add (this.svgFileName_Sizer);
add (this.azimuth_NC);
add (this.elevation_NC);
add (this.scaleXY_NC);
add (this.scaleZ_NC);
//add (this.mtf_NC);
add (this.brightness_NC);
add (this.shading_Sizer);
add (this.backgroundColor_Sizer);
add (this.polygonFill_Sizer);
add (this.polygonBorder_Sizer);
add (this.buttons_Sizer);
this.windowTitle = TITLE + " v" + VERSION;
this.adjustToContents();
this.setFixedSize();
_3dplot_dialog.prototype = new Dialog;
function FullViewIdAsValidViewId( fullId )
return fullId.replace( "->", "_" );
function main()
if(ImageWindow.activeWindow.isNull)
DieError("There is no active image");
console.hide();
for ( ;; )
if (!(new _3dplot_dialog).execute())
return;
if ( !perspecParams.srcView.isNull )
break;
(new MessageBox( "No source view has been selected!",
TITLE, StdIcon_Error, StdButton_Ok )).execute();
console.show();
console.writeln( "<end><cbr><br>***** 3D Profiling Script *****" );
console.flush();
var startts = new Date;
// Extract the luminance of the source image
var src = new Image();
perspecParams.srcView.image.extractLuminance(src);
ApplySTF(src, perspecParams.srcView.stf);
// Allow the user to abort this script
console.abortEnabled = true;
// Allow status monitoring for our working image
src.statusEnabled = true;
// Create the perspective
var xform=new _3dplot_xform(src, perspecParams);
try
var width = Math.round( xform.limits.width );
var height = Math.round( xform.limits.height );
if ( perspecParams.svgOutput )
console.writeln( "<end><cbr>Generating SVG output: ", perspecParams.svgFileName );
var svg = new SVG( perspecParams.svgFileName, width, height );
RenderSVG( src, svg, xform.limits, xform.points, perspecParams );
else
var newid = FullViewIdAsValidViewId( perspecParams.srcView.fullId ) + "_3dplot";
console.writeln( "<end><cbr>Generating image output: ", newid );
var isTransparent = (perspecParams.backgroundColor & 0xff000000) != 0xff000000;
var w = new ImageWindow( width, height, isTransparent ? 4 : 3, 8, false, true, newid );
var v = w.mainView;
var i = v.image;
RenderImage( src, i, xform.limits, xform.points, perspecParams );
v.endProcess();
w.show();
var endts = new Date;
console.writeln( format( "<end><cbr>3D view: %.2f s", (endts.getTime() - startts.getTime())/1000 ) );
catch(err)
console.writeln( err );
main();
// EOF pjsr/3DPlot.js - Released 2009/06/05 15:52:25 UTC
