Author Topic: 3D star profile / Perfil estelar en 3D (BETA)  (Read 29761 times)
« Reply #15 on: 2009 April 10 11:28:12 »
A few quick modifications:
- The script can now be aborted by the user. So a size warning/error is no longer needed (IMO).
- The script shows progress information on the console.
- The perspective transformation points are now calculated faster. See changes in the CreatePerspective function (line 44).
- The MTF transformation is now carried out using a HistogramTransformation instance on a temporary copy of the working image. See the ApplyMTF function (line 73).
#include <pjsr/UndoFlag.jsh>
#include <pjsr/FillRule.jsh>
#include <pjsr/ColorSpace.jsh>
// Creates the parameters object.
function DefaultParams()
   var params={};
   params.angle = 30;   // Perspective angle in degrees
   params.scaleXY = 6;  // Scale factor for X and Y axis
   params.scaleZ = 500; // Scale factor for Z axis
   params.mtf=0.1;      // Midtones transfer value (0,1)
   params.backgroundColor=0xff403000;
   params.polygonFill=0xffffffff;
   params.polygonBorder=0x10000000;
   params.useShading=true; // Apply shading effect
   params.lightBrightness=700; // Light intensity for the shading effect
   // Precalculated sin and cos of angle
   params.sin_angle=Math.sin(params.angle*Math.PI/180);
   params.cos_angle=Math.cos(params.angle*Math.PI/180);
   return params;
// Perspective transformation -- Replaced by faster inline code; see below
function Perspective(x, y, z, params)
   with(params){
      // x
      var new_x = (x - ys) * scaleXY;
      // y
      var new_y = ycs - scaleZ * z;
      // z
      new_y -= scaleZ * z; // -----> ???
   return new Point (new_x, new_y);
// Applies the perspective transformation to all the pixels in the image
function CreatePerspective(src, limits, perspecParams)
   src.initializeStatus( "Computing 3D coordinates", src.height );
   // Calculates the coordinates of each pixel applying the perspective transformation
   var xform=[];
   limits.left=limits.top=1e10;
   limits.right=limits.bottom=-1e10;
   for (var y = 0; y < src.height; y++) {
      xform[y]=[];
      var ys = y * perspecParams.sin_angle;
      var ycs = y * perspecParams.cos_angle * perspecParams.scaleXY;
      for (var x = 0; x < src.width; x++) {
         var z = src.sample( x, y );
         var pixel = new Point( (x - ys)*perspecParams.scaleXY,
                                ycs - perspecParams.scaleZ*z );
         //Perspective(x, ys, ycs, src.sample(x,y), perspecParams);
         xform[y][x]=pixel;
         if(pixel.x<limits.left)   limits.left=pixel.x;
         if(pixel.x>limits.right)  limits.right=pixel.x;
         if(pixel.y<limits.top)    limits.top=pixel.y;
         if(pixel.y>limits.bottom) limits.bottom=pixel.y;
      src.advanceStatus( 1 );
   return xform;
function ApplyMTF(src, mtf)
   // Faster solution using a process instance
   var HT = new HistogramTransformation;
   with ( HT )
      H = // c0, m, c1, r0, r1
      [[0, 0.5, 1, 0, 1],
       [0, 0.5, 1, 0, 1],
       [0, 0.5, 1, 0, 1],
       [0, mtf, 1, 0, 1],
       [0, 0.5, 1, 0, 1]];
   var wtmp = new ImageWindow( 1, 1, 1, 16, false, src.colorSpace != ColorSpace_Gray );
   var v = wtmp.mainView;
   v.beginProcess( UndoFlag_NoSwapFile );
   v.image.assign( src );
   v.endProcess();
   HT.executeOn( v, false ); // no swap file
   src.assign( v.image );
   wtmp.close();
      for (var x = 0; x < src.width; x++){
         var z=Math.mtf(mtf,src.sample(x,y));
         src.setSample(z,x,y);
function DieError(message)
   var msgb = new MessageBox(message,"Error generating 3D view");
   msgb.execute();
   throw Error( message );
function main()
   if (ImageWindow.activeWindow.currentView.isNull)
      DieError("There is not an active image");
   if(ImageWindow.activeWindow.currentView.image.width>500 ||
      ImageWindow.activeWindow.currentView.image.height>500)
         DieError("The image is bigger than 500x500 pixels");*/
   console.show();
   console.writeln( "<end><cbr><br>***** 3D Profiling Script *****" );
   console.flush();
   var startts = new Date;
   // Extract the luminance of the source image
   var src = new Image();
   ImageWindow.activeWindow.currentView.image.extractLuminance(src);
   // Inits the parameters
   var perspecParams = DefaultParams();
   // Apply a midtones transformation
   if ( perspecParams.mtf != 0.5 )
      ApplyMTF(src, perspecParams.mtf);
   // Allow the user to abort this script
   console.abortEnabled = true;
   // Allow status monitoring for our working image
   src.statusEnabled = true;
   // Create the perspective
   var limits = new Rect;
   var xform = CreatePerspective(src,limits,perspecParams);
   //with(limits) console.writeln(format("%f %f %f %f",left,top,right,bottom));
   // Create the output window
   var w = new ImageWindow (Math.round(limits.width), Math.round(limits.height), 3, 8, false, true, '_3dplot');
   var v = w.currentView;
   var i = v.image;
   // Start of the process
   var bmp = new Bitmap (i.width, i.height);
   var g = new Graphics (bmp);
   // Applies a translation to the graphics to center the image
   g.translateTransformation(-limits.left,-limits.top);
   src.initializeStatus( "Rendering 3D profile", src.height-1 );
   v.beginProcess(UndoFlag_NoSwapFile);
      bmp.fill (perspecParams.backgroundColor);
      g.pen =  new Pen (perspecParams.polygonBorder);
      var fillbrush=[];
      if(perspecParams.useShading){
         for(var c=0; c<256;++c)
            fillbrush[c]=new Brush(0xFF000000 | (c<<16) | (c<<8) | c);
      }else
         g.brush = new Brush (perspecParams.polygonFill);
      // Paint the polygons from back to front
      for (var n = 0; n < src.height-1; n++) {
         for (var m = 0; m < src.width-1; m++) {
               var slope=src.sample(m,n)-src.sample(m+1,n)+
                         src.sample(m,n+1)-src.sample(m+1,n+1);
               var color=Math.round(slope * perspecParams.lightBrightness + 128);
               color=Math.max(0,Math.min(255,color));
               g.brush=fillbrush[color];
            var polygon=new Array(
               xform[n][m],
               xform[n][m+1],
               xform[n+1][m+1],
               xform[n+1][m]);
            g.drawPolygon (polygon);
      g.end();
      i.blend (bmp);
   v.endProcess();
   w.show();
   var endts = new Date;
   console.writeln(format ("<br />3D view: %.2f s",(endts.getTime() - startts.getTime()) / 1000));
main();
Offline David Serrano
« Reply #16 on: 2009 April 10 11:49:48 »
Quote from: "Andres.Pozo"
I have added an optional shading effect:
Diossss qué bueno!!! xD
I've seen you removed the parameter "alt" I had in my original script. It was meant to be a configurable value that indicated the altitude over the terrain, indicated in degress. Thus, a value of 0 would render the grid as if we were on the ground (untested!) and a value of 90 would give a 2D grid.
        return ShowError("The image is bigger than 500x500 pixels");
I agree with Juan on this. The image dimensions limit I suggested was meant to be some kind of "Are you sure?" dialog, to avoid someone ;) asking for a higher limit. I like to allow users to crash their machine if they want to. Detecting the amount of RAM in the system would be useful to make the limit dynamic.
I would implement it as an absolute number of pixels (width * height), thus allowing the user to plot a 2000x10 image.
Of course, the original idea is of David Serrano and he should be who granted the permission.
The idea may be mine, but at this point the code is yours ;).
 David Serrano
Offline Andres.Pozo
« Reply #17 on: 2009 April 10 13:23:34 »
I have merged the improvements of Juan in the code that I was writting. I also have implemented the visualization using false color mapping the height to a color palette.
Example of false color with shading:
Example of false color without shading:
   var params={};
   params.polygonBorder=0x80000000;
   params.lightBrightness=2000; // Light intensity for the shading effect
   params.palette = [ [0x80,0,0] , [0,0x80,0] , [0,0,0xC0], [0x80,0,0x80], [0x80,0x80,0], [0x80,0x80,0x80] ];
   return params;
   var xform=[];
      xform[y]=[];
         var z= src.sample(x,y);
         var pixel=new Point( (x - ys)*perspecParams.scaleXY,
         xform[y][x]=pixel;
   return xform;
   with ( HT )
      [[0, 0.5, 1, 0, 1],
       [0, 0.5, 1, 0, 1],
       [0, 0.5, 1, 0, 1],
       [0, mtf, 1, 0, 1],
       [0, 0.5, 1, 0, 1]];
   v.endProcess();
   wtmp.close();
   var msgb=new MessageBox(message,"Error generating 3D view");
   msgb.execute();
function ApplyLighting(basecolor, light)
   var r=(basecolor[0]*light/1000);
   r=r>255?255:r;
   var g=(basecolor[1]*light/1000);
   g=g>255?255:g;
   var b=(basecolor[2]*light/1000);
   b=b>255?255:b;
   return 0xFF000000 | (r<<16)| (g<<8) | b;
function RenderImage(src,i,limits,xform,perspecParams)
   g.antialiasing=true;
   var fillbrush=[];
   if(!perspecParams.useShading){
      for(var c=0;c<perspecParams.palette.length;c++)
         fillbrush[c]=new Brush(0xFF000000 | (perspecParams.palette[c][0]<<16) | (perspecParams.palette[c][1]<<8) | perspecParams.palette[c][2]);
      g.pen =  new Pen (perspecParams.polygonBorder,0);
   } else
      // Using shading the polygon borders should be less visible
      g.pen =  new Pen ((perspecParams.polygonBorder&0x00FFFFFF) | 0x20000000);
   // The median of the source image is the level of the "floor" of the 3D image
   var stats = new ImageStatistics;
   stats.generate(src);
   var minz=stats.median;
         var  z1=src.sample(m,n),
              z2=src.sample(m+1,n),
              z3=src.sample(m,n+1),
              z4=src.sample(m+1,n+1);
         // Get the palette index
         //var z=(z1+z2+z3+z4)/4;
         var z=Math.max(Math.max(z1,z2),Math.max(z3,z4));
         z=(z-minz)/(1-minz); //rescale for mapping the palete to (minz,1)
         var palidx=Math.round(z*perspecParams.palette.length);
         palidx=palidx<0 ? 0 : (palidx>=perspecParams.palette.length ? perspecParams.palette.length-1 : palidx);
            // Get the lighting factor
            var slope=z1-z2+z3-z4;
            var lighting=(slope+0.5)*perspecParams.lightBrightness;
            lighting=lighting<0 ? 0 : Math.round(lighting);
            g.brush=new Brush(ApplyLighting(perspecParams.palette[palidx], lighting));
         } else
            g.brush=fillbrush[palidx];
            xform[n][m],
            xform[n][m+1],
            xform[n+1][m+1],
            xform[n+1][m]);
   g.end();
   i.blend (bmp);
function main()
   if(ImageWindow.activeWindow.currentView.isNull)
      return DieError("There is not an active image");
   console.show();
   console.flush();
   var src =new Image();
   var perspecParams=DefaultParams();
   if( perspecParams.mtf!=0.5)
   var limits=new Rect;
   var xform=CreatePerspective(src,limits,perspecParams);
   var newid;
   if(ImageWindow.activeWindow.currentView.isPreview)
      newid=ImageWindow.activeWindow.mainView.id+'_'+ImageWindow.activeWindow.currentView.id+'_3dplot';
   else
      newid=ImageWindow.activeWindow.currentView.id+'_3dplot';
   var w = new ImageWindow (Math.round(limits.width), Math.round(limits.height), 3, 8, false, true, newid);
   try{
      var i = v.image;
      RenderImage(src,i,limits,xform,perspecParams);
      v.endProcess();
      w.show();
   } catch(err)
      w.close();
      console.writeln(err);
main();
« Reply #18 on: 2009 April 10 13:29:03 »
Voodoo magic. And I've been programming since I got a ZX-81 too many years ago :) Very impressive.
Offline Andres.Pozo
« Reply #19 on: 2009 April 11 12:13:27 »
Quote from: "David Serrano"
I have reimplemented the possibility of rotating the 3D view. It is implemented using a linear projection matrix so it is quite fast.
These are a couple of screenshots:
   var params={};
   params.azimut = 30;    // Perspective angle in degrees
   params.elevation = 20; // Perspective elevation angle
   params.scaleZ = 50;   // Scale factor for Z axis
   params.mtf=0.5;        // Midtones transfer value (0,1)
   params.palette = [ [0x80,0,0] , [0,0x80,0] , [0,0,0xC0], [0x80,0,0x80], [0x80,0x80,0], [0,0x80,0x80], [0x80,0x80,0x80] ];
   return params;
function CreatePerspective(src, limits, perspecParams, minz)
   var xform=[];
   // Modify the zscale in order to normalize the peak height
   // when the mtf changes
   var zscale=perspecParams.scaleZ/(1-minz);
   // Projection matrix
   var alpha=Math.rad(90-perspecParams.elevation);
   var beta=Math.rad(perspecParams.azimut);
   var m00=Math.cos(beta);
   var m10=-Math.sin(beta);
   var m20=0;
   var m01=Math.cos(alpha)*Math.sin(beta);
   var m11=Math.cos(alpha)*Math.cos(beta);
   var m21=-Math.sin(alpha);
      xform[y]=[];
         var z= src.sample(x,y)*zscale;
         var pixel=new Point( (m00*x+m10*y)*perspecParams.scaleXY,
                              (m01*x+m11*y+m21*z)*perspecParams.scaleXY );
         xform[y][x]=pixel;
   return xform;
   with ( HT )
      [[0, 0.5, 1, 0, 1],
       [0, 0.5, 1, 0, 1],
       [0, 0.5, 1, 0, 1],
       [0, mtf, 1, 0, 1],
       [0, 0.5, 1, 0, 1]];
   v.endProcess();
   wtmp.close();
   msgb.execute();
   r=r>255?255:r;
   g=g>255?255:g;
   b=b>255?255:b;
function RenderImage(src,i,limits,xform,perspecParams,minz)
   var fillbrush=[];
   } else
         var zM=Math.max(Math.max(z1,z2),Math.max(z3,z4));
         var zm=Math.min(Math.min(z1,z2),Math.min(z3,z4));
         var z=(zm+zM)/2;
         } else
            xform[n][m],
            xform[n][m+1],
            xform[n+1][m+1],
            xform[n+1][m]);
   g.end();
   i.blend (bmp);
function main()
   console.show();
   console.flush();
   var xform=CreatePerspective(src,limits,perspecParams,minz);
   var newid;
   else
   try{
      var i = v.image;
      RenderImage(src,i,limits,xform,perspecParams,minz);
      v.endProcess();
      w.show();
   } catch(err)
      w.close();
main();
« Reply #20 on: 2009 April 11 15:30:12 »
Smooth color transitions. They are somewhat ugly but I don't care about it. The strange profile was caused by a quick Morphological ;):
Differences:
--- 3dplot/3dplot-0.7.js 2009-04-11 22:53:11.000000000 +0200
+++ 3dplot/3dplot-0.8.js 2009-04-12 00:32:50.000000000 +0200
@@ -16,6 +16,7 @@
+   params.palette_elems = 256;
    return params;
@@ -108,6 +109,33 @@
+// the resulting palette doesn't have to be exactly 'num' elements long.
+function ExpandPalette(params)
+   var p = params.palette;
+   var num = params.palette_elems;
+   var expanded = new Array;
+   var steps = Math.round (num / p.length);  // steps between two provided palette elements
+   for (var c = 0; c < p.length - 1; c++) {
+      var from = p[c];
+      var to = p[c+1];
+      var step_red   = (to[0] - from[0]) / steps;
+      var step_green = (to[1] - from[1]) / steps;
+      var step_blue  = (to[2] - from[2]) / steps;
+      for (s = 0; s < steps; s++) {
+         var new_red   = from[0] + s * step_red;
+         var new_green = from[1] + s * step_green;
+         var new_blue  = from[2] + s * step_blue;
+         expanded.push ([ new_red, new_green, new_blue ]);
+   // add last user-supplied palette element
+   expanded.push (p[p.length-1]);
+   params.palette = expanded;
@@ -120,6 +148,8 @@
+   ExpandPalette (perspecParams);
    var fillbrush=[];
Full code:
   var params={};
   return params;
   var xform=[];
   var m20=0;
      xform[y]=[];
         xform[y][x]=pixel;
   return xform;
   with ( HT )
      [[0, 0.5, 1, 0, 1],
       [0, 0.5, 1, 0, 1],
       [0, 0.5, 1, 0, 1],
       [0, mtf, 1, 0, 1],
       [0, 0.5, 1, 0, 1]];
   v.endProcess();
   wtmp.close();
   msgb.execute();
   r=r>255?255:r;
   g=g>255?255:g;
   b=b>255?255:b;
      var from = p[c];
      var to = p[c+1];
   var fillbrush=[];
   } else
         var z=(zm+zM)/2;
         } else
            xform[n][m],
            xform[n][m+1],
            xform[n+1][m+1],
            xform[n+1][m]);
   g.end();
   i.blend (bmp);
function main()
   console.show();
   console.flush();
   var newid;
   else
   try{
      var i = v.image;
      v.endProcess();
      w.show();
   } catch(err)
      w.close();
main();
 David Serrano
Offline Andres.Pozo
« Reply #21 on: 2009 April 12 02:18:23 »
That's a very good idea!!
One warning, the rendering function only works with an azimut angle between 0º an 90º. For different angles the painting of the polygons must be done in a different order.
Also, if the rendering was done painting triangles (instead of 4 vertex polygons) the color transitions and the shading would be smoother. However, the rendering would be also much slower and perhaps the polygon borders should not be drawn.
« Reply #22 on: 2009 April 12 04:54:03 »
Finally, some user interface.
I've given up fighting against NumericControl.slider.setRange, even after reading a thread discussing its usage. The intended interval for the MTF is 0.005 but it jumps from 0.001 to 0.010 when changing the range from [1, 1000] to [1, 1001]. I'd also like the Light brightness to go in steps of 10.
Andrés, do you agree on GPLv3?
    3DPlot v0.9
    Iteratively stretch histogram with an appropriate luminance mask each time.
    Copyright (C) 2009  Andrés Pozo, Juan Conejero, David Serrano
    This program is free software: you can redistribute it and/or modify
    it under the terms of the GNU General Public License as published by
    the Free Software Foundation, version 3 of the License.
    This program is distributed in the hope that it will be useful,
    but WITHOUT ANY WARRANTY; without even the implied warranty of
    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    GNU General Public License for more details.
    You should have received a copy of the GNU General Public License
    along with this program.  If not, see <http://www.gnu.org/licenses/>.
    Changelog:
   0.9:   License, changelog, bare-bones user interface.
   0.8:   Smooth color transitions.
   0.7:   Reimplemented the possibility of rotating the 3D view.
   0.6:   Visualization now maps the height to a color palette.
   0.5:   The script can now be aborted by the user.
          The MTF transformation is now carried out using a HT.
   0.4:   Optional shading effect added.
   0.3:   The resulting image shows the full extent of the 3D view.
          The code has been reorganized and structured.
          A MTF is applied to the image to improve the visualization.
          The perspective transformation has been simplified again.
          There is a couple of checks before starting the algorithm.
   0.2:   It now works on grayscale images.
          The 3D image is centered in the output image.
          The code is a bit simpler.
          It is now 7 times faster.
   0.1:   Initial test version.
#define VERSION "0.9"
#include <pjsr/FrameStyle.jsh>
#include <pjsr/NumericControl.jsh>
#feature-id 3DPlot
#feature-info Please write something here.
//#feature-icon 3dplot.xpm
   this.azimut = 30;    // Perspective angle in degrees
   this.elevation = 20; // Perspective elevation angle
   this.scaleXY = 6;    // Scale factor for X and Y axis
   this.scaleZ = 50;   // Scale factor for Z axis
   this.mtf=0.5;        // Midtones transfer value (0,1)
   this.backgroundColor=0xff403000;
   this.polygonFill=0xffffffff;
   this.polygonBorder=0x80000000;
   this.useShading=true; // Apply shading effect
   this.lightBrightness=2000; // Light intensity for the shading effect
   this.palette_elems = 256;
   this.palette = [ [0x80,0,0] , [0,0x80,0] , [0,0,0xC0], [0x80,0,0x80], [0x80,0x80,0], [0,0x80,0x80], [0x80,0x80,0x80] ];
var perspecParams = new DefaultParams;
   var xform=[];
   var m20=0;
      xform[y]=[];
         xform[y][x]=pixel;
   return xform;
   with ( HT )
      [[0, 0.5, 1, 0, 1],
       [0, 0.5, 1, 0, 1],
       [0, 0.5, 1, 0, 1],
       [0, mtf, 1, 0, 1],
       [0, 0.5, 1, 0, 1]];
   v.endProcess();
   wtmp.close();
   msgb.execute();
   r=r>255?255:r;
   g=g>255?255:g;
   b=b>255?255:b;
      var from = p[c];
      var to = p[c+1];
   var fillbrush=[];
   } else
         var z=(zm+zM)/2;
         } else
            xform[n][m],
            xform[n][m+1],
            xform[n+1][m+1],
            xform[n+1][m]);
   g.end();
   i.blend (bmp);
function _3dplot_dialog() {
   this.__base__ = Dialog;
   this.__base__();
   // help label
   this.helpLabel = new Label (this);
   with (this.helpLabel) {
      frameStyle = FrameStyle_Box;
       margin = 4;
       wordWrapping = true;
       useRichText = true;
       text = "<b>3DPlot v"+VERSION+"</b> - A " +
          "script that wants some description.";
   // iterations
   this.azimut_NC = new NumericControl (this);
   with (this.azimut_NC) {
      label.text = "Azimut:";
      setRange (0, 90);
      slider.setRange (0, 90);
      slider.minWidth = 200;
      setPrecision (0);
      setValue (perspecParams.azimut);
      toolTip = "Azimut of view.";
      onValueUpdated = function (value) {
        perspecParams.azimut = value;
   // median
   this.elevation_NC = new NumericControl (this);
   with (this.elevation_NC) {
      label.text = "Elevation over the terrain:";
      setRange (0, 90);
      setPrecision (0);
      setValue (perspecParams.elevation);
      toolTip = "Elevation of the observer over the terrain.";
         perspecParams.elevation = value;
   // scaleXY
   this.scaleXY_NC = new NumericControl (this);
   with (this.scaleXY_NC) {
      label.text = "Scale of X and Y coordinates:";
      setRange (1, 10);
      slider.setRange (1, 10);
      slider.minWidth = 50;
      setPrecision (0);
      setValue (perspecParams.scaleXY);
      toolTip = "Scale of X and Y coordinates.";
         perspecParams.scaleXY = value;
   // scaleZ
   this.scaleZ_NC = new NumericControl (this);
   with (this.scaleZ_NC) {
      label.text = "Scale of Z coordinate:";
      setRange (1, 100);
      slider.setRange (1, 100);
      slider.minWidth = 80;
      setPrecision (0);
      setValue (perspecParams.scaleZ);
      toolTip = "Scale of Z coordinate.";
         perspecParams.scaleZ = value;
   // mtf
   this.mtf_NC = new NumericControl (this);
   with (this.mtf_NC) {
      label.text = "MTF:";
      setRange (0.005, 0.995);
      slider.setRange (1, 990);
      slider.minWidth = 800;
      setPrecision (3);
      setValue (perspecParams.mtf);
      toolTip = "MidtonesTransferFunction to apply in order to improve faint detail visualization.";
         perspecParams.mtf = value;
   // useShading
   this.shading_CB = new CheckBox (this);
   with (this.shading_CB) {
      text = "Use shading";
      checked = perspecParams.useShading;
      onCheck = function (checked) { perspecParams.useShading = checked; }
      toolTip = "Check to toggle the use of shading.";
   // lightBrightness
   this.brightness_NC = new NumericControl (this);
   with (this.brightness_NC) {
      label.text = "Light brightness:";
      setRange (100, 5000);
      slider.setRange (1, 490);
      setPrecision (0);
      setValue (perspecParams.lightBrightness);
      toolTip = "Intensity of the light.";
         perspecParams.lightBrightness = value;
   // buttons
   this.ok_Button = new PushButton (this);
   this.ok_Button.text = " OK ";
   this.ok_Button.onClick = function() { this.dialog.ok(); };
   this.cancel_Button = new PushButton (this);
   this.cancel_Button.text = " Cancel ";
   this.cancel_Button.onClick = function() { this.dialog.cancel(); };
   this.buttons_Sizer = new HorizontalSizer;
   this.buttons_Sizer.spacing = 4;
   this.buttons_Sizer.addStretch();
   this.buttons_Sizer.add (this.ok_Button);
   this.buttons_Sizer.add (this.cancel_Button);
   // pack everything
   this.sizer = new VerticalSizer;
   with (this.sizer) {
      margin = 6;
      spacing = 6;
      add (this.helpLabel);
      addSpacing (4);
      add (this.azimut_NC);
      add (this.elevation_NC);
      add (this.scaleXY_NC);
      add (this.scaleZ_NC);
      add (this.mtf_NC);
      add (this.shading_CB);
      add (this.brightness_NC);
      add (this.buttons_Sizer);
   this.windowTitle = "3DPlot v" + VERSION;
   this.adjustToContents();
_3dplot_dialog.prototype = new Dialog;
var dialog = new _3dplot_dialog;
function main()
   if (!dialog.execute())
      return;
   console.show();
   console.flush();
   //var perspecParams=DefaultParams();
   var newid;
   else
   try{
      var i = v.image;
      v.endProcess();
      w.show();
   } catch(err)
      w.close();
main();
 David Serrano
Offline Andres.Pozo
« Reply #23 on: 2009 April 12 06:30:20 »
David, the GPLv3 would be fine. However, I think that Juan should be also added to the list of contributors. He added some good optimizations and most of the code for console management.
« Reply #24 on: 2009 April 12 07:22:52 »
Oops, that's true. I've updated the code accordingly ;).
 David Serrano
« Reply #25 on: 2009 April 12 13:33:57 »
Hi Guys,
Fantastic utility !!
Might I make a suggestion for further, future, development?
Take your basic idea, and code structure, but use it to visualise FWHM of all stars in the image.
Could it be used to visualise star elongation (where FWHM in the X-axis does not equal FWHM in the Y-axis) ?
Could it be used to visualise areas of the image where FWHM is different from the 'median' FWHM?
To me, this sort of approach would allow you to visualise optical abberations such as coma and collimation.
Also, if the stars themselves were 'removed' (by masking, etc.) it could be used to visualise any background gradients - perhaps it would have some use in just visualising the image extracted in a DBE operation.
I can see that, before too long, PixInsight will need an interface that allows it to drop a Process Container instance on each newly acquired image, as it arrives in a specified directory - to allow us imagers to see what our 'RAW' data looks like, dark and flat calibrated, perhaps even with a running 'average combine', maybe even Kalmann-filtered if required.
PixInsight - 'per PI ad astra'
« Reply #26 on: 2009 April 12 14:19:56 »
I've noted a couple of strange behaviours in this script:
The red portion of the palette dominates half of the height. It seems like the beginning of the palette was situated near the largest star, at the lower left edge of the mesh, and that cells below that level were painted red. I think the first element of the palette should be assigned to black pixels in the source image, and the last element to white pixels.
The second weirdness is in the content of the defined preview. There seems to be a green arc along the star. It could be an artefact or it could be genuine, I don't know, but there doesn't seem to be any height change that justifies the color.
Nice donuts eh? ;)
 David Serrano
« Reply #27 on: 2009 April 12 16:46:19 »
New version with improved dialog and a few optimizations.
One of the changes is somewhat subtle but very important. In previous versions a function was used to calculate 3D rendition points and the limits of the rendered scene, namely:
The problem is that the limits argument was intended to be passed by reference, but that is impossible: in JavaScript, function parameters are always passed by value.
Luckily, limits was working as a by-reference argument (or the script wouldn't work at all), but this is only due to some peculiarities of my implementation (the way I've embedded Mozilla's JavaScript engine into PI Core, and how I've connected some internal PI objects to expose them through the JS runtime).
For this reason, I have replaced the old CreatePerspective function by a _3dplot_xform object that owns both the transformation's point cube (the points member) and the transformation's bounding rectangle (the limits member).
    3DPlot v1.0
    A script to generate three-dimensional image renditions.
    Copyright (C) 2009  Andrés Pozo, David Serrano, Juan Conejero
    Changelog:
   1.0:   Several improvements to the user interface and a few optimizations.
          Replaced CreatePerspective() by a _3dplot_xform object.
          Some identifiers changed for improved naming coherency.
#define TITLE "3DPlot"
#define VERSION "1.0"
#feature-id 3DPlot
function _3dplot_params()
   this.srcView = ImageWindow.activeWindow.currentView;
   this.azimuth = 30;    // Perspective angle in degrees
var perspecParams = new _3dplot_params;
function _3dplot_xform(src, perspecParams, minz)
   this.points=new Array;
   this.limits=new Rect( 1e10, 1e10, -1e10, -1e10 );
   var beta=Math.rad(perspecParams.azimuth);
   var m20=0;
   var m21=-Math.sin(alpha)*zscale;
      this.points[y]=new Array;
      var m10y = m10*y;
      var m11y = m11*y;
         var z = src.sample(x,y);
         var p = new Point( m00*x + m10y, m01*x + m11y + m21*z );
         p.mul( perspecParams.scaleXY );
         this.points[y][x] = p;
         if (p.x < this.limits.left)   this.limits.left = p.x;
         if (p.x > this.limits.right)  this.limits.right = p.x;
         if (p.y < this.limits.top)    this.limits.top = p.y;
         if (p.y > this.limits.bottom) this.limits.bottom = p.y;
   gc();
   with ( HT )
      [[0, 0.5, 1, 0, 1],
       [0, 0.5, 1, 0, 1],
       [0, 0.5, 1, 0, 1],
       [0, mtf, 1, 0, 1],
       [0, 0.5, 1, 0, 1]];
   v.endProcess();
   wtmp.close();
   msgb.execute();
   r=r>255?255:r;
   g=g>255?255:g;
   b=b>255?255:b;
      var from = p[c];
      var to = p[c+1];
   var fillbrush=[];
   } else
         var z=(zm+zM)/2;
         } else
            xform[n][m],
            xform[n][m+1],
            xform[n+1][m+1],
            xform[n+1][m]);
   g.end();
   i.blend (bmp);
   this.__base__();
   var labelWidth1 = this.font.width( "Polygon border color:" );
   var editWidth1 = 9*this.font.width( "0" );
   var editWidth2 = 12*this.font.width( "0" );
   // help label
       margin = 4;
       useRichText = true;
       text = "<p><b>" + TITLE + " v" + VERSION + "</b> &mdash; A " +
          "script to generate three-dimensional image renditions.</p>" +
          "<p>Copyright &copy; 2009 Andr&eacute;s Pozo / David Serrano / Juan Conejero</p>";
   // source image
   this.srcImage_Label = new Label( this );
   this.srcImage_Label.minWidth = labelWidth1;
   this.srcImage_Label.text = "Source image:";
   this.srcImage_Label.textAlignment = TextAlign_Right|TextAlign_VertCenter;
   this.srcImage_ViewList = new ViewList( this );
   this.srcImage_ViewList.minWidth = 250;
   this.srcImage_ViewList.getAll(); // include main views as well as previews
   this.srcImage_ViewList.currentView = perspecParams.srcView;
   this.srcImage_ViewList.toolTip = "<p>Select the image to be rendered.</p>";
   this.srcImage_ViewList.onViewSelected = function( view )
      perspecParams.srcView = view;
   this.srcImage_Sizer = new HorizontalSizer;
   this.srcImage_Sizer.spacing = 4;
   this.srcImage_Sizer.add( this.srcImage_Label );
   this.srcImage_Sizer.add( this.srcImage_ViewList, 100 );
   // azimuth
   this.azimuth_NC = new NumericControl (this);
   with (this.azimuth_NC) {
      real = false;
      label.text = "Azimuth:";
      label.minWidth = labelWidth1;
      setRange (0, 90);
      slider.minWidth = 250;
      edit.minWidth = editWidth1;;
      setValue (perspecParams.azimuth);
      toolTip = "<p>Azimuth angle in degrees.</p>";
        perspecParams.azimuth = value;
   // elevation
      real = false;
      label.text = "Elevation:";
      setRange (0, 90);
      toolTip = "<p>Observer's elevation angle above the ground, in degrees.</p>";
   // scaleXY
      real = false;
      label.text = "X-Y plane scale:";
      setRange (1, 10);
      toolTip = "<p>Scale of X and Y coordinates in rendition pixels per image pixels.</p>";
   // scaleZ
      real = false;
      label.text = "Z-axis scale:";
      setRange (1, 100);
      toolTip = "<p>Scaling factor of Z-axis coordinates.</p>";
   // mtf
      label.text = "Midtones balance:";
      setRange (0, 1);
      slider.setRange (1, 500);
      setPrecision (3);
      toolTip = "<p>This parameter is part of a histogram transformation applied to " +
                "improve faint detail visualization.</p>";
   // lightBrightness
      real = false;
      label.text = "Brightness:";
      slider.setRange (1, 50);
      toolTip = "<p>Intensity of incident light.</p>";
   // useShading
      toolTip = "<p>If this option is selected, a special shading algorithm will be used " +
                "to enhance the 3-D rendition.</p>";
   this.shading_Sizer = new HorizontalSizer;
   this.shading_Sizer.addSpacing( labelWidth1+4 );
   this.shading_Sizer.add( this.shading_CB );
   this.shading_Sizer.addStretch();
   // background color
   this.backgroundColor_Label = new Label( this );
   this.backgroundColor_Label.text = "Background color:";
   this.backgroundColor_Label.textAlignment = TextAlign_Right|TextAlign_VertCenter;
   this.backgroundColor_Label.minWidth = labelWidth1;
   this.backgroundColor_Edit = new Edit( this );
   this.backgroundColor_Edit.text = format( "%X", perspecParams.backgroundColor );
   this.backgroundColor_Edit.setFixedWidth( editWidth2 );
   this.backgroundColor_Edit.toolTip = "<p>Background color encoded as a 32-bit hexadecimal integer.<br/>" +
                                "(AARRGGBB format: AA=alpha (transparency), RR=red, GG=green, BB=blue)</p>";
   this.backgroundColor_Edit.onEditCompleted = function()
      perspecParams.backgroundColor = parseInt( this.text, 16 );
      this.text = format( '%X', perspecParams.backgroundColor );
   this.backgroundColor_Sizer = new HorizontalSizer;
   this.backgroundColor_Sizer.spacing = 4;
   this.backgroundColor_Sizer.add( this.backgroundColor_Label );
   this.backgroundColor_Sizer.add( this.backgroundColor_Edit );
   this.backgroundColor_Sizer.addStretch();
   // polygon fill color
   this.polygonFill_Label = new Label( this );
   this.polygonFill_Label.text = "Polygon fill color:";
   this.polygonFill_Label.textAlignment = TextAlign_Right|TextAlign_VertCenter;
   this.polygonFill_Label.minWidth = labelWidth1;
   this.polygonFill_Edit = new Edit( this );
   this.polygonFill_Edit.text = format( "%X", perspecParams.polygonFill );
   this.polygonFill_Edit.setFixedWidth( editWidth2 );
   this.polygonFill_Edit.toolTip = "<p>Polygon fill color encoded as a 32-bit hexadecimal integer.<br/>" +
   this.polygonFill_Edit.onEditCompleted = function()
      perspecParams.polygonFill = parseInt( this.text, 16 );
      this.text = format( '%X', perspecParams.polygonFill );
   this.polygonFill_Sizer = new HorizontalSizer;
   this.polygonFill_Sizer.spacing = 4;
   this.polygonFill_Sizer.add( this.polygonFill_Label );
   this.polygonFill_Sizer.add( this.polygonFill_Edit );
   this.polygonFill_Sizer.addStretch();
   // polygon border color
   this.polygonBorder_Label = new Label( this );
   this.polygonBorder_Label.text = "Polygon border color:";
   this.polygonBorder_Label.textAlignment = TextAlign_Right|TextAlign_VertCenter;
   this.polygonBorder_Label.minWidth = labelWidth1;
   this.polygonBorder_Edit = new Edit( this );
   this.polygonBorder_Edit.text = format( "%X", perspecParams.polygonBorder );
   this.polygonBorder_Edit.setFixedWidth( editWidth2 );
   this.polygonBorder_Edit.toolTip = "<p>Polygon border color encoded as a 32-bit hexadecimal integer.<br/>" +
   this.polygonBorder_Edit.onEditCompleted = function()
      perspecParams.polygonBorder = parseInt( this.text, 16 );
      this.text = format( '%X', perspecParams.polygonBorder );
   this.polygonBorder_Sizer = new HorizontalSizer;
   this.polygonBorder_Sizer.spacing = 4;
   this.polygonBorder_Sizer.add( this.polygonBorder_Label );
   this.polygonBorder_Sizer.add( this.polygonBorder_Edit );
   this.polygonBorder_Sizer.addStretch();
   // ### TODO: Better color selection controls - Include a ColorSelectionDialog object in PJSR?
   // ### TODO: Allow selecting palettes
   // buttons
   this.ok_Button.text = "OK";
   this.cancel_Button.text = "Cancel";
   this.buttons_Sizer.spacing = 8;
   // pack everything
   with (this.sizer) {
      margin = 8;
      spacing = 6;
      addSpacing (4);
      add (this.srcImage_Sizer);
      add (this.azimuth_NC);
      add (this.mtf_NC);
      add (this.shading_Sizer);
      add (this.backgroundColor_Sizer);
      add (this.polygonFill_Sizer);
      add (this.polygonBorder_Sizer);
   this.windowTitle = TITLE + " v" + VERSION;
   this.setFixedSize();
function FullViewIdAsValidViewId( fullId )
   return fullId.replace( "->", "_" );
function main()
   if(ImageWindow.activeWindow.isNull)
      DieError("There is no active image");
   console.hide();
   for ( ;; )
      if (!(new _3dplot_dialog).execute())
         return;
      if ( !perspecParams.srcView.isNull )
         break;
      (new MessageBox( "No source view has been selected!",
                       TITLE, StdIcon_Error, StdButton_Ok )).execute();
   console.show();
   console.flush();
   perspecParams.srcView.image.extractLuminance(src);
   var minz=src.median();
   var xform=new _3dplot_xform(src, perspecParams, minz);
   //with(xform.limits) console.writeln(format("%f %f %f %f",left,top,right,bottom));
   var newid = FullViewIdAsValidViewId( perspecParams.srcView.fullId ) + "_3dplot";
   var w = new ImageWindow (Math.round(xform.limits.width),
                            Math.round(xform.limits.height), 3, 8, false, true, newid);
   try{
      var v = w.mainView;
      var i = v.image;
      RenderImage(src, i, xform.limits, xform.points, perspecParams, minz);
      v.endProcess();
      w.show();
   } catch(err)
      w.close();
main();
Offline Andres.Pozo
« Reply #28 on: 2009 April 13 02:00:14 »
It seems that this image has been generated using a very low mtf value. The algorithm is using the median of the image (after applying the mtf) to set the origin of the palette. All the points lower than the median are assigned the first element of the palette. With a very low mtf the noise of the image is magnified and also the range of values lower than the median.
We could try to find another value for the origin of the palette, but with normal mtf's, the median works fine. The minimum z could be an option, but the cold pixels would distort the palette. Perhaps we could try finding the value in the percentile 1% of the histogram or something similar.
Also, the lighting function is a quite simple approximation. It multiplies the lighting factor by the RGB channels of the base color. The black color can not be used because the lighting function would always return 0. The effect of "black" would be achieved using a dark (20%?) gray.
« Reply #29 on: 2009 April 13 14:55:15 »
Not exactly. The image was bright in itself because it's part of M45 nebulosity. The largest star is Alcyone, the brightest one in the cluster.
I, as a user, would see no distortion in the cold pixels. After all, if the background in my image isn't absolute black, the background in the generated 3D map shouldn't be absolute red (or whatever color was the first in the palette). I guess we have two equally valid points of view over this matter ;).
 David Serrano
