Bernd, I've never changed any of those settings, I went into format explorer to DBL check a coordinate origin setting and did not see one? ( Srry , I may sound confused here, I've never messed with that, ) I do know that the QHY10 mirror and flips (both I think) , but I've never touched orrientstion untill after stacking so figured as long as all my subs and calibration frames are raw orientation from camera I'd be good.
I think in Format Explorer/FITS you should change the setting of 'Coordinate origin' to 'lower left corner'. Then the images are not flipped vertically.
Again sorry, but how would I get u the Output to Console?
When a process in Pixinsight has finished, you can look into the Process Console. There you will find the description about what was done and whether an error occurred. Most processes output important parameters that should be inspected after the process terminated.
, And lights were calibrated with Master bias, dark and flat, with Optimize and calibrate ONLY checked for the darks.
OK, I think that is the key point here. I calibrated your light frame in two ways:
1) No dark frame optimization
Master Bias unchecked;
Master Dark checked, calibrate not checked, optimization not checked;
Master Flat checked, calibrate not checked.
2) With dark frame optimization
Master Bias checked, calibrate not checked;
Master Dark checked, calibrate checked, optimize checked;
Calibration 1) looked OK to me. Calibration 2) (the way you did it) looked strange because of an uneven background color. In Calibration 2) the following warning appeared in the console:
** Warning: No correlation between the master dark and target frames (channel 0).".
That means, the dark frame optimization algorithm did not find a correlation between the light frame and the Master Dark and as result, no dark frame subtraction was performed at all. That is not what you want. The reason why dark frame optimization doesn't find a correlation between the light frame and the MasterDark is presumably that your sensor has very few hot pixels.
Please try the following:
- Calibrate your flats using only Master Bias, no Master Dark.
For the calibration of the light frames try both of the following posibilities and compare the differences.:
- calibrate your light frames according to 1) or
- calibrate your light frames using Master Bias and Master Flat, but no Master Dark.
Hope that helps!
Bernd
