Author Topic: BPP No Longer Produces MasterLights  (Read 1938 times)
Offline Farzad_k
« on: 2017 February 19 13:22:17 »
Hello,
I have been going back and forth with the BPP script while learning PI and suddenly the BPP has stopped producing MasterLights. It only produces MasterBias and MasterDarks (I am not using Flats).
I have tried to figure out what I may have done to cause this to happen and am running out of ideas. Anyone here have had the experience and might know what could be wrong?
I have attached a snapshot of the BPP UI.
Thanks a lot.
Farzad
Re: BPP No Longer Produces MasterLights
« Reply #1 on: 2017 February 20 09:30:01 »
if the calibration was bad, then the signal in the calibrated lights can be destroyed... then StarAlignment fails and there's no registered frames to integrate. not sure if that's what happened to you - check BPP's log (which is printed in the console) to try to get an idea of what's happening.
