Author Topic: Shortcut of PI 1.4  (Read 9944 times)
Offline bitli
Shortcut of PI 1.4
« on: 2009 March 30 12:04:37 »
I haven't find a list of shortcuts, so I built one.  It may not be complete or may include inacuracies, so please check for later posts for corrections
PixInsight 1.4 (Windows)
Shortcuts in main windows
File:
        Open                    Ctrl+O
        Open a copy             Ctrl+Shift+O
        Open a Location         Ctrl+Alt+O
        Save                    Ctrl+S
        Save As                 Ctrl+Shift+S
        Print                   Ctrl+P
        Exit                    Ctrl+X
Edit:
        Copy (view to clip board)       Ctrl+C
        New Image from Clip Board       Ctrl+V
View:
        Explorer Windows
                Control Explorer        Ctrl+Alt+P
                Format Explorer         Ctrl+Alt+F
                View Explorer           Ctrl+Alt+V
                History Explorer        Ctrl+Alt+H
                Load View Explorer      Ctrl+Alt+Shift+V
                Load History Explorer   Ctrl+Alt+Shift+H
        Processing Console      Crtl+Alt+C
        Script Editor           Ctrl+Alt+E
        Realtime Preview        Ctrl+Alt+T
        Show Controler Bar      Ctrl+Alt+B (toggle)
        ZoomIn                  Ctrl++
        ZoomOut                 Ctrl+-
        Zoom
                1:1             Ctrl+1
                1:<n>           Ctrl+Shift+<n>  (n from 2 to 8)
                <n>:1           Ctrl+<n>        (n from 2 to 8)
        Zoom to fit             Ctrl+0
        Fit  view               Ctrl+W
        Full Screen             Ctrl+Alt+0 (toggle)
Image:
        Undo                    Ctrl+Z          (also appy to different contexts)
        Redo                    Ctrl+Y          (also appy to different contexts)
        New image               Ctrl+N
        Invert image            Ctrl+I
Preview:
        Next preview            Ctrl+Right
        Previous preview        Ctrl+Left
        Undo/Redo: <operation>  Ctrl+Shift+Z
        Store                   Ctrl+Alt+S
        Reset                   Ctrl+R
Mask:
        Select mask             Ctrl+M
        Remove mask             Ctrl+Alt+M
        Invert mask             Ctrl+Shift+I
        Enable mask             Ctrl+Shift+M
Process: (via console)
        Image Container         Ctrl+Alt+I
Script:
        Run                     F9
Workspace:
        Select Workspace <n>    Alt+<n> (n from 1 to 4)
Window
        Next image window       Ctrl+PgDown
        Active Image to Back    Ctrl+End
Help:
        Help Index              F1              (send to site)
        Online Documentation    Shift F1        (send to site)
In image context (also right click)
        Color management
                Color Management Enabled        F11
                Color Proofing Disabled         Ctrl+F11
                Gamut Check Disable             Shift+F11
        Display
                RGB/K                           Ctrl+Shift+0
                Red                             Ctrl+Shift+R
                Green                           Ctrl+Shift+G
                Blue                            Ctrl+Shift+B
                Luminance CIE L                 Ctrl+Shift+L
                Chrominance CIE a=R b=G         Ctrl+Shift+C
                Luminance CIE Y                 Ctrl+Shift+Y
        Transparency
                Show Transparency               F10
                Background Brush                Ctrl+F10
                White Background                Shift+F10
                Black Brackground               Alt+F10
        STF
                Enable STF                      F12
                Reset STF                       Ctrl+F12
        Mode
                Readout                         Alt+R
                Zoom In                         Alt+Z
                Zoom Out                        Alt+Shitf+Z
                Center                          Alt+C
                Pan                             Alt+P
                New Preview                     Alt+N
                Edit Preview                    Alt+E
                Dynamic Operation               Alt+D
In Script Editor
        Cut                             Ctrl+X
        Copy                            Ctrl+C
        Paste                           Ctrl+V
        Select All                      Ctrl+A
        Find                            Ctrl+F
        Replace                         Ctrl+R
        Find/Replace again              F3
        Goto Line                       Ctrl+L
        Compile&Run                     F9
        Compile                         Ctrl+F9
Process explorer:
        Up/down arrow to select process
        First letter of process name to select process
Gestures:
        File Open Image                 Double click in backgound
                                        Drag file to background
        Many drag and drop
bitli
Offline David Serrano
Shortcut of PI 1.4
« Reply #1 on: 2009 April 03 00:40:18 »
Hey, nice job!!
I don't seem to have privileges to make this post sticky... someone else will have to do it! ;)
 David Serrano
Shortcut of PI 1.4
« Reply #2 on: 2009 April 05 11:35:04 »
Excellent, and well worth-while exercise.
Thanks.
Now, just before the post is 'made sticky', could someone just clarify which keys I need to press to get the shortcut for 'Save As' - one of the three keys in the original post doesn't seem to be available on my keyboard !!
Offline bitli
Shortcut of PI 1.4
« Reply #3 on: 2009 April 05 12:14:28 »
Oh shit :-)
Corrected in various places on the first post, thanks - bitli.
