Author Topic: Method to create galaxy mask  (Read 2507 times)
Offline jshortt
« on: 2017 February 12 13:06:16 »
Hi all, I'm working on processing some data that I have for M77 and I'm following methods from Inside PixInsight. A galaxy mask is need for curves and other stepon the nonlinear RGB. I got a good galaxy mask by taking the layer 8 output from the ExtractWaveletLayers script on my L_mask and then factoring it by the inverse of my star_mask.
Any comments on this method? It seems pretty simple and the result mask looks pretty good to me. I haven't gotten far enough along in the processing to use this mask yet.
John
Offline RickS
Re: Method to create galaxy mask
« Reply #1 on: 2017 February 12 22:59:01 »
Sounds like a reasonable approach, John.  If the mask looks good it probably is  :)
Offline jshortt
« Reply #2 on: 2017 February 13 08:22:23 »
Thanks. I'll update on how it works out
John
Offline mmirot
« Reply #3 on: 2017 February 14 00:31:51 »
Another method  Range Mask for the galaxy - StarMask= Galaxy alone.   I use multiscale tools as you suggest too.
Offline jshortt
« Reply #4 on: 2017 February 14 06:13:40 »
I found that the mask worked well except for the stars in front of the galaxy and this was because the star mask needed to be improved. Once I did that it worked well for Curves, HDRMT, LHE and MLT to bring out colour and details in the galaxy. Unfortunately I only have 30 minutes per R/G/B and so I am pushing it with this data
John
